When composing or replying to an email, if I only paste text and then close the window, it used to prompt me to save the draft. Now it closes without any confirmation, and the content is not saved. Please fix this issue.
What version of eM Client are you using ?
As could be you have an older version and need and update.
Also how long do you wait before closing the compose or reply window after pasting the text ?
As could be “you need to wait a little longer” so the draft then saves when you close the window.
For me personally “it just automatically saves in the drafts folder after about 2-3 secs of the compose window being open, and never has prompted if I just close the window.
There is a Setting via “Menu / Settings (Preferences) / General / Confirmations” eg: Ask before modifying email properties that might possible prompt if the mail body changes. Just a thought. These are normally all checked by default so maybe have a look in Confirmations.
