Please let me know how I can setup eM Client to sync with an external ICS URL using anonymous authentication. I’ve been unsuccessful so far. Here is what I tried…
I am trying to add an external ICS URL to sync from an Outlook.com shared calendar. The calendar is publicly shared via a private URL. When I add the ICS calendar URL, I have to provide dummy login credentials, since the setup “wizard” doesn’t allow anonymous account setup. Once the eM Client account is created, I can change it to anonymous authentication. However, the communication immediately dumps exception “9:48:09 AM xxxxxxxxxxx [CalDAV / CardDAV] MailExceptions.OperationException: Subfolder synchronization for folder “xxxxxxx” failed with following error: Forbidden”
Hi Jan - Thanks for the quick response. I guess I’ll have to find a server-side solution to hook-up to my CalDAV server and do the sync there. Do you guys know of anything written in PHP / cURL that could do it? In the meantime, I’ll go use some Bingfoo… cheers!
