Just downloaded the program and like it but, the icon did not appear on the computer screen. I tried resetting the computer, repairing the program then uninstalling and reinstalling the program. No change.
Any suggestions?
If you have Windows, go to Start / Apps and scroll down till you see eM Client and then drag the icon to the desktop which will make a shortcut icon. Or also right click “send to taskbar” as well.
Or click the “Search” icon down at the bottom left of Windows and type “Mailclient.exe” and when it appears you can right click on it and “open folder location”. Then right click on Mailclient.exe and choose send to desktop.
