Hello Thaddeus,
unfortunately on all Windows systems, even if you set different default browser, most applications will reach out to Internet Explorer for authentications and such. So make sure you enable JavaScript in IE and see if this solves your problem.
Best regards,
That is not solving the issue. My IE allows JavaScript.
And when I go to settings to verify it it it confirmed.
Hi Thaddeus,
I’m not sure which version you are running at the moment, but try installing this one - http://www.emclient.com/dist/v6.0.234…
It has some of the fixes for google authentication problems, so maybe it will solve yours too.
