This appears to ome up every so often, but I have not seen a solution, apart from use Thuderbird.
Send email works, IMAP sync has failed after several days working.
I have reinstalled, tried it with anti virus software off, etc etc
It works fine with Thunderbird on this machine, and Outlook on other machines, so it is not the anti virus software, (Same on both machines), the network, the server, the ISP etc - only em client left. Checked all the account settings, and compared to thunderbird and Outlook.
log is
15:08:43 Online state: changed to online due to NetworkAvailability
15:08:43 [email protected] [IMAP] Uploading messages: To folder [email protected]/Sent
15:08:43 [email protected] [IMAP] Synchronizing subfolders: For folder [email protected]/
15:09:14 [email protected] [IMAP] Uploading messages: Done
15:09:14 [email protected] [IMAP] MailClient.Accounts.ConnectionException: No server response within 30 second timeout. —> System.IO.IOException: No server response within 30 second timeout.
15:09:14 at MailClient.Imap.Base.Connection.Connect(Func`1 getStream)
15:09:14 at MailClient.Imap.Base.Connection.Connect(String receiveHost, Int32 receivePort, Boolean explicitSsl)
15:09:14 at MailClient.Protocols.Imap.ConnectionPoolEntry.Reconnect(CancellationToken cancellationToken)
15:09:14 — End of inner exception stack trace —
15:09:14 at MailClient.Protocols.Imap.ConnectionPoolEntry.Connect(CancellationToken cancellationToken)
15:09:14 at MailClient.Protocols.Imap.ConnectionPool.AcquireConnection(Folder mailFolder, Boolean idle, Boolean forStore)
15:09:14 at MailClient.Protocols.Imap.Synchronizer.AppendCommand.ExecuteInternal(WorkerStatus status)
15:09:14 at MailClient.Protocols.Imap.Synchronizer.ImapCommand.Execute(WorkerStatus status)
15:09:14 at MailClient.Commands.Command.Process(WorkerStatus status)
15:18:43 [email protected] [IMAP] Synchronizing subfolders: For folder [email protected]/
TLS Handshake maybe?
Any ideas please.
em Client is a nice looking product, but I need it to work for longer than 3 days.
