I can't get correct settings for sending mail. Incoming mail settings configured correctly after setup. Remedy?
Auto configuration correctly set up incoming mail but I can not get correct setting for outgoing mail. What to do? I am basically computer illiterate so need very simple directions…
Hello, what mail service are you using with eM Client and what version of the application are you currently using on your computer, can you please check the exact release number in Help > About?
Are you seeing any errors when trying to send your email through eM Client?
