there is an error in receiving emails on my Email Client
If there is an error, you will either get a pop-up, or if you have disabled that, you can find errors in Menu > Tools > Operations.
If you post the error here, someone can offer advice.
Some common issues can be solved by disabling you anti-virus application and then try again. If that works, then you need to look at the anti-virus application settings.
