I am trying to import from Outlook and it does not work!!????
IMPORTING FROM OUTLOOK
IF you are using a trial version of microsoft office it will not work to to import from. The trial version of outlook is installed to a Q: drive called click to run. Which can not be seen by the EM client because it does not see outlook on the C: drive.
can I ask you what versions of eM Client, Windows and Outlook you use?
