Is there some way I can sync the calendar across two computers?
If your calendar is a Google calendar or synced with another online service like Outlook.com etc. you can setup the same calendar account on both computers.
If you have only a local calendar, consider moving it to an online account.
It’s the calendar that’s built in to EM Client.
So that is called a local calendar. It will be in Local Folders, and is only viewable on that one computer.
But you could add your Google Calendar to both computers. You still use GMail right? Then you will have 2 calendars on your computer; one local and one online. So long as you create events in the online one, they will be synced with any other email clients connecting to that calendar.
Does that make sense?
Cool. Thanks again Gary. I’ll try that.
