I can not repair eM Client: System.Data.SQLite.SQLiteException (0x80004005): SQL logic error or missing database в MailClient.Storage.Data.BlobStream.Create(IDbConnection connection, String databaseName, String tableName, String columnName, Int64 rowId, Boolean readOnly)
в MailClient.Storage.Data.DatabaseCopyTool.CopyContents(Table table, Boolean sortDesc)
в MailClient.Storage.Data.DatabaseCopyTool.CopyTableData(Table table)
в MailClient.Storage.Data.DatabaseCopyTool.CopyInternal(String specificTable, Boolean copyIndexesViewsAndTriggers)
в DbRepair.CorruptionChecker.CheckCorruption(RepairOptions repairOptions, CancellationToken token)
в DbRepair.CheckingProcess.Check(CancellationToken token)
Data:
Table: Accounts
databaseFile: accounts.dat
If you are using IMAP, I would just delete the database and start again.
