You can easily recover contacts from impaired or corrupt NK2 files of MS Outlook by using the SysInfo Outlook Cached Contact Recovery Tool. This software quickly scans your damaged NK2 files and restores all cached contacts safely. You just need to add the NK2 file to the tool, and it will recover all your saved Outlook contacts without any data loss. After recovery, you can save the contacts in CSV (Comma Separated Value) or VCF (vCard) format, making them easy to import into Outlook or mobile devices. The tool is simple to use, completely secure, and works with all versions of Windows and MS Outlook.
