Is it possible to mark unread emails with red text?
Hi, unfortunately this is not possible using the standard eM Client options, however you should be able to create a rule for all your incoming messages that would categorize the message with a newly setup red category.
And setup to show color of category as text color.
However note this would only work for newly received unread email in your inbox as eM Client can not process the rule if messages are being moved by a server rule to another folder or in case the application receives the message through IMAP after it was already received and marked as read on another device.
Paul
Thanks for the reply.
It would be a good feature to add to the next release.
Thank you for the suggestion, we’ll consider improving this in future releases of eM Client.
Paul
