How to import events from iCalendar?
To import iCalendar events from .ics files select File ->Import in the main menu:
Select the Import events from iCalendar (.ics) option and click Next:
Click Browse… to specify an Internet location or a local folder containing the .ics files.
Click Select folder… next to the second address bar to select a calendar folder in which your events will be stored.
Click Finish to complete the importing process and close the wizard.
Tried those exact steps with both Google and Hotmail calendars - nothing shows up
Are you sure you have correctly export from Google and Live! calendar? I’m not sure about MSN, but Google’s calendar setup interface isn’t exactly easy to use. Those are the steps for export to iCal format: http://support.google.com/calendar/bi…
