how to import e-maills from Chaso intellect
I am switching from Chaso intellect to eM Client inc
How can I do ths
I am not sure how exactly Chaos works, but you should have an option to export your data - after the export is done, you can Import them to eM Client if they are in the supported format (eml for messages, csv for contacts etc.)
