How to Distinguish Between Read and Unread Messages-Ver. 10.1
After upgrading to version 10.1.4588, new, or unread mail are the same color and boldness as read messages. How do I correct this? In previous versions new messages were in bold font, and after opening it became un-bold. This was fine with me, so how do I set this up in 10.1?
Possibly the Theme hasnt for some unknown reason updated the same in the new version 10 when you upgraded. V10 still has the same bold font for unread and non bold font for read.
So try going to “Menu / Settings (Preferences) / Appearance / Themes” and try changing to a different theme and then back again to whatever theme you had previously and see if it fixes it.
Also apart from the built-in Themes, there is also some really good User created Themes you might prefer to make the unread bold standout better via the following page.
If you do download a user created theme, then click the Import button at the bottom of Themes. Then click Apply and Save Settings.
I found the problem. I had it set to “mark messages as read after 1 second.” How do I set it to mark messages read after opening or clicking on them? That was how it worked on older versions.
Also, how do I increase the font size on everything except messages in the inbox, such as column labels (delete, reply, forward), etc., and everything in the settings page, dropdowns, etc, and compose window?
