New Message > Menu > Insert > Image as Link - or - just hit Crtl + M
Sorry, I got eMC in German but that should be it in English - roughly.
Hello. Thanks for the answer. But I have a Problem of another type. Clicking on the image should a transition to a site. This we do in the outlook. In emclient possible to make the transition to the link through the picture ?? For us it is very important. We plan to use the PRO version.
Hello Mihail,
For creating a hyperlink from an image 1) insert the image into the text body 2) select the image and while the image is selected, insert a link. The link will be created from the selected image.
Maurice
Ahhh! At Adobe they’d call it a hidden gem
