Yes, yes, it’s working after the tip of TNCS.
theres no skype on drop-down menu (Instant Messaging/Add contact/instant messaging service), i use ver 4.0.15145.0. eM client enable in Skype.
How can i add skype account to eM Client?
Peter
Actually, it should be fully automatic after enabling eM Client in Skype.
Hi, I can’t get this to work with version 6.0 of eM Client.
Please can you help.
Thanks
Hi, Skype support was removed from eM Client.
This is not because we wanted, but Microsoft stopped supporting API for implementation of Skype protocol into 3rd party applications (which is eM Client in relation to Skype itself).
Jan
Jan,
Thanks for that reply. Obviously not the one I wanted but I realised there’s not much you can do about that.
Thanks,
Simon
We are not happy with this either, but there is no way how to fight this with Microsoft from our side.
Thank you for your understanding.
Jan
Jan,
I do feel like things have gone downhill with Skype over the last few months (possibly Microsoft influence?) and I’m starting to try out Google Hangouts, which I believe eM Client supports.
Thanks,
Simon
Yes, eM Client supports talk over Google Hangouts.
Jan
Same problem here using Em Client 6.0 and the latest Skype version. No automatic prompt is showing up in Skype.
Btw, there is no ‘Skype’ section in the ‘Settings’ menu either. Did you remove the Skype option out of Em Client?
Thanks,
Arjan
Ah sorry, no I see the comment above! No more Skype in Em Client anymore.
To bad!!
