HOW TO CHANGE WEATHER LOCATION IN CALENDAR
Hi Barry,
Menu > Tools > Settings > Calender > Weather
Tick " Enable Weather"
Then  Location and “Change”
Hi Digger,
 tried this but my location did not change the location shown is where i was located about 9 years ago
Hi Barry , thanks for the feedback.
Are you saying that selecting  your actual location
that it wil not change to that?
Which Calender are you sync’íng with?
Google Calender ? other ?
Will the info in this post help?
https://forum.emclient.com/emclient/topics/calendar-weather
