I just reinstalled eM Client on a different computer (the computer I was using it on bricked itself).
How do I activate a newly-installed 8.2.1479 eM Client with my existing license?
There is no Help->License option that I can find, nor anything in Settings that seemed relevant.
That is very strange you don’t have the License option available.
Where did you get the installation file from ?
Also is this a Windows or Macintosh ver ?
miércoles 19 agosto 2021 :: 1029hrs (UTC +01:00)
Hi @CCB
Please confirm your version as: 8.2.1479
I’m not certain what you can and cannot see so can you do this?
Menu ->Help ->License ->If you can you should be able to enter your License here
I say should because even though your old computer died the License server will possibly still think the License is in use - if this is the case contact [email protected] who will be able to resolve this for you.
Skybat
