Made the mistake of switching to Postbox, now I want to get out.
How do I import mail from Postboxs into eM ?
if you used IMAP accounts just create these accounts in eM Client again - it will download emails from server. If you had some local items (and used POP3) in Postbox just export/save these items in Postbox and then import them to eM Client through menu File->Import.
Regards
EM Client support import from Outlook, Outlook Express, The Bat! and Thunderbird format. Standard mail mbox file are also supported. If Postbox support export to any of these formate, eM will be able to imported it.
After less than a minute search, it seems Postbox is using the mbox file, you should be able to import without a problem.
