I have my gmail calendar and an older “local folder” calendar … how do I merge the older into the gmail calendar?
Do you want to merge view or merge items definitely ?
if views
Check every calendar folder you want to display
If items
select “agenda” view, then select all, right click an copy or move to folder “gmail”.
Is that working ?
