NULL
What do you mean with AKO?
AKO = Army Knowledge Online = Military E-mail. If you do a search on-line for AKO Outlook setup, you’ll see all of the configurations that they provide for SMTP and IMAP. I’ve set these up in eM Client the same way, but it still will not work. I’ve tried modified settings, and it’s still not working.
Does it produce any error message? A quick Google of “AKO outlook problem” seems to centre around certificate issues.
Same problem. Too much ambiguity for accuracy
