How can I tell if eM has finished syncing gmail?
I have a client with a rather large gmail account. I’m suggesting he move from outlook to eM client because it seems to work pretty well and looks to provide better gmail apps integration than Outlook with the apps sync tool.
How can I tell where the local sync is up to? how do I know when it’s actually finished syncing all of the folders. It’s been running for quite some time and I haven’t found a way to tell where it’s at…?
When you open the Operations window, you should see progress bars indicating synchronization status - can you confirm that?
