Can anyone tell me how to stop my eM Client from searching for encryption certificates and keys?
I just cannot find where to turn that off.
Thanks,
Frank
Thanks,
Frank
If you are using eM Client for Windows, suggest to go to “Menu / Settings” and click the (Signing and Encryption) menu partway down and see if there are any “Certificates or Keys in there”.
Thanks Cyberzok,
That’s was one of the first thing I did and nope there aren’t any at all.
For what it’s worth I’m using the free version.
Any other suggestions?
I know there is a way as I did it a very long time ago with an earlier version but cannot find how to stop eM Client this time on the latest version.
viernes 27 agosto 2021 :: 1941hrs (UTC +01:00)
From memory this is enabled during account setup and I don’t think it can be edited.
If I’m correct delete the particular account and set up without enabling encryption
Skybat
Thanks skybat! Apologies for the late reply. I will give that a go!
Hi Skybat and all.
I’ve tried it again and uninstalled and re-installed; however, there was no opportunity to turn encryption off during setup!
I am now using Version 8.2.1473 (04b618f) can anyone offer another suggestion?
Thanks,
Frank
jueves 09 septiembre 2021 :: 1153hrs (UTC +01:00)
I do not know why you do not have the ‘encryption’ option.
I have just tested both Automatic & Manual setup and the encryption option is
available with both.
The only difference is that I am using the latest ver 8.2.1509.0
If you wish you can update to this at:
Skybat
[email protected]
Hablo principalmente español, portugués e inglés, también un conocimiento práctico de varios otros.
Thanks once again skybat!
You have been very helpful. I could not find your version and could only find version the version I had. HOWEVER, the one thing I had not done previously was to delete the data base. I decided to do that this time around and I also allowed the exe file I downloaded to delete my current eM Client. Not sure if all of that helped but it seems that it worked!
Thanks again and cheers!
Frank
jueves 09 septiembre 2021 :: 2011hrs (UTC +01:00)
Good that you have been able to fix your problem.
I do not understand why you could not see the updated file.
Here is another download link:
https://www.emclient.com/dist/v8.2.1509/setup.msi
Skybat
[email protected]
Hi Skybat,
Sorry for the late reply as I was traveling. It was my mistake as I simply did not use the link you gave me in the first place!
I will update my version again in any case and once again thank you very much for your excellent help and support.
Frank
