I’m looking for tight integration with Todoist so I can create tasks from emails and see the items in the todo pane. Any ideas? Thanks.
Hi Rich, I don’t know if you have an answer to this yet, but if you are using google emClient will update the calendar from google, which will itself be updated by Todoist with google integration.
You can then forward any email, from any client, to Todoist and it will work.
I wonder if emClient has the ability to create AddOns - as a Todoist addon would be great.
Or similar. Google Tasks is quite hopeless for anything beyond a few simple things.
