With the same smtp settings on my android mobile it works fine. Untill few days back even emclient was working fine. I dont know what happened ? It says
12:30:13 " Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond."
12:30:13 at MailClient.Protocols.Smtp.SmtpSendCommand.Connect(WorkerStatus status)
12:30:13 at MailClient.Protocols.Smtp.SmtpSendCommand.Execute(WorkerStatus status)
12:30:13 at MailClient.Commands.Command.Process(WorkerStatus status)
Kindly help.
