Can you please tell me how the gmail labels works in eM? I don’t understant. All my email are labeled as important… is there a way to unlabel them rather than each on individually???
Hello Brooke,
this is an issue in the BETA we are aware of and will be fixed.\
For now, you can either Select all the messages in your Inbox using the Ctrl-A shortcut and right-click>Categorize and remove the Important label,
or go to the webmail settings for Gmail and under the Labels tab uncheck the option to ‘Show in IMAP’ for the Important label.
