I’ve got trouble after installing the new version 2.7 over the old one 2.6
Now program wouldn’t start
This is the raport
System.DllNotFoundException: Kan DLL sqlite3 niet laden: Kan opgegeven module niet vinden. (Uitzondering van HRESULT: 0x8007007E)
bij System.Data.SQLite.UnsafeNativeMethods.sqlite3_open_v2(Byte[] utf8Filename, IntPtr& db, Int32 flags, IntPtr vfs)
bij System.Data.SQLite.SQLite3.Open(String strFilename, SQLiteOpenFlagsEnum flags, Int32 maxPoolSize, Boolean usePool)
bij System.Data.SQLite.SQLiteConnection.Open()
bij DbRepair.DbTools.OpenConnection(String fileName)
bij DbRepair.Form1.CheckConsistency(Int32& affectedRows, String& consistencyError)
bij DbRepair.Form1.Check(Object state)
it seems you are missing some files for proper functioning of the application. These files are contained in .zip archive at ftp://support2:Heslo123*@emclient.com/sqllite.zip. You should extract them to eM Client program folder in your Program Files folder.
It’s a very very scary trip.
I own a small company and all my email was jet gone.
Even the activation of this account offcourse did not work.
So I started the setup 2.7 again but now in a brand new directory,.
all so called it different.
Much to my surprise a update of the database occured.
I did put my fingers in my ears. the tention was to much
Et voila, the bleedin’ thing is OK,
Good work at eMclient, thanks
