HC mode does not work properly V11
Try following steps using HC Paper mode.
  1. Click menu
  2. Click Print
  3. Look at Pages item.
    Both options are checked. Can not check/uncheck at all.
    This happens for all RadioButton control.
Hi, thank you for reporting it. It should be resolved in the version 11.3.1389 (https://licensing.emclient.com/api/update/emclient.appinstaller?version=11.0.1389.0)
