System.UnauthorizedAccessException: Der Zugriff auf den Pfad “C:\Users\Bernhard\AppData\Roaming\Microsoft\Windows\Start Menu\Programme” wurde verweigert. bei System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) bei System.IO.FileSystemEnumerableIterator1.AddSearchableDirsToStack(SearchData localSearchData) bei System.IO.FileSystemEnumerableIterator
1.MoveNext() bei System.Collections.Generic.List1..ctor(IEnumerable
1 collection) bei System.IO.Directory.GetDirectories(String path, String searchPattern, SearchOption searchOption) bei DbRepair.PerAccountExecutor.Execute(String dataStoreLocation, ExecutePerAccount action) bei DbRepair.MissingFilesChecker.CheckMissingF
Hello Bernhard,
We’re sorry for the inconvenience but your database has unfortunately been damaged and you’ll need to start with a new one. That means that your locally saved data will be lost, although if you have your data on the server or made backups regularly, it shouldn’t be a problem.
If eM Client can’t find the database folder in the default location (C:\Users\username\AppData\Roaming) with the default name (‘eM Client’), it will create a new one. In order to start with a new database, simply turn eM Client off and rename the ‘eM Client’ folder to e.g. ‘eM Client old database’.
Maurice
