My contacts with Gravatar avatars no longer display their image. Not quite sure when this started, currently on version 8.2.1721
I tried deleting the avatar cache, no help. After startup, the failed_requests.dat file is full of entries such as: gravatar_535a2c7c2c4b96b48d8ca7ff6077674c / 637979899468392023
Looks like EmClient can no longer communicate over https to get the icons
HTTPS handshake to www.gravatar.com (for #18) failed. System.Security.Authentication.AuthenticationException A call to SSPI failed, see inner exception. < The message received was unexpected or badly formatted
I have more contacts with Gravatar avatars than I can be bothered to count, way in excess of 400 company colleagues, there are no issues on my system.
I am running eMC v9 on Win11 & v8 on Win10
Apart from deleting the avatar image cache, you can also force eM Client to âre-download your avatarâ as per the following eM Client support article. The below worked for me previously" when i couldnât get my Gravatar to show.
How to change my own email account avatar?
Posted by Olivia Rust on 24 May 2019 15:59
IMPORTANT: Please note that since eM Client updates the downloaded avatars every 30 days, the avatar changes wonât be immediately visible.
However, you can force eM Client to re-download new images by disabling and re-enabling the download of images from external sources, which will clear the image cache:
Go to Menu > Settings > Contacts > General
Disable the option âDownload avatars from external sourcesâ and click âApplyâ
Then enable the option âDownload avatars from external sourcesâ again and click âOkâ
Your new image will show up now
@cyberzork Yep, tried all that, no go. I did discover however that the problem is not EMC itself, but rather the configuration of SCHANNEL on my Windows machine. I found a program that helps you with registry settings related to cipher suites, protocols, etc that are used by a .NET app.
I think what happened is that the Gravatar server stopped supporting an older protocol, and my machine couldnât deal with it. At any rate, after configuring my machine, itâs now working again.
