Google Calendar sync problem
Hi, im on em - client 5.0.17263.0 and if i compose a new event online on google calendar page and change it by em-client to another calendar it tells me: The owner of the calendar must either be the organizer or the attendee of an event that is imported.
If i compose a new event with em-client and change the calendar on google it works.
Have here also one version em-client4 (softmaker office 2012) and it works (same settings)…
Thanks Detlef
Is the event in eM Client saved in the same calendar as the original event?
No, it is saved in an different calendar.
Please send me the problematic event saved as .ics file directly at [email protected]. Thank you.
Solved! Thanks George for the new update, works!
