It first happened I think week ago and second time today. eM Client won’t receive my gmail mails in another folders than Inbox (set to receive folder’s mail as offline…) even if I force it by Send/receive all button or if I go to the folder. I have these emails at gmail web-interface so they are there for sure. As soon as I try to do IMAP logs of it, i.e. go to appropriate menu and check IMAP (logs) and press OK it receives mails instantly (without restart). So then I uncheck IMAP (logs) and everything goes ok then. My version is 4.0.14479.0, do you have some fix/update for that?
please run the tool available from http://www.emclient.com/tools/emstack… after it happens again. It should generate a log file (starting with “eM Client Stack” in your Documents folder) that will help us analyze the problem in more detail. Please send this file directly to me: [email protected]
Note: Run the application after you won’t receive your mail, but do not try to create any logs in the Logging window.
Thank you.
