gmail contacts not syncing with my iPhone
I can create a new gmail contact via the gmail web interface and it Appears under  My Contacts in gmail and syncs up with my iPhone contacts. When I use the eM Client to create a new contact, it, by default, seems to show up under the  Other Contacts section in gmail and does not sync with my phone. Is there a way to change how the eM Client creates a gmail contact?
Hello Don,
Gmail doesn’t use the same folder system as eM Client, instead it uses the labels that we change into folders in eM Client. In order to move the contacts into requested labels in Gmail web interface, you need to mark the contact with appropriate label. Then it should work correctly.
Russel
Worked like a charm Russel. Thanks!
