Hi, I’m using EMclient with a gmail account (I have to use the IMAP configuration), every time I configure the gmail account the unread messages are visible in triple copy. How could I fix it?
Thanks!
Thanks!
I will need your IMAP logs, go to tools - settings - advanced, check IMAP under your account, apply and restart eM Client.
Simulate steps that leads to your issue and after that send logs… to [email protected] together with this topic’s URL in subject.
regards
Jan
Hi John,
I sent you the logs.
Hope you can help me.
Paolo.
logs received and forwarded.
Jan
