Several times a day the eM client shows an application error and stops working and this message is shown.
When you click the button “show error”, the following message appears:
eM Client (7.0.27943.0)Windows: Microsoft Windows NT 10.0.14393.0, Framework: 4.0.30319.42000
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.NullReferenceException: Object reference not set to an instance of an object.
at MailClient.Storage.Views.BaseCollectionView1.UpdateAndNotify(NotifyCollectionChangedEventArgs
1 changeEvent)
— End of inner exception stack trace —
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Delegate.DynamicInvokeImpl(Object[] args)
at MailClient.Storage.Views.UIDispatcherQueue.ProcessNotifications()
at MailClient.Storage.Views.UIDispatcherQueue.Dispatch(Delegate methodDelegate, Object[] parameters)
at MailClient.Storage.Views.ItemCollectionView2.folder_RefreshItems(Object sender, ItemPropertyChangedEventArgs
1 e)
at MailClient.Storage.Application.ItemCollection2.\<\>c\_\_DisplayClass74\_0.<onrefreshitems>b__0()<br> at MailClient.Storage.Application.TaskQueue.<.ctor>b__4_0()<br> at System.Threading.ThreadHelper.ThreadStart_Context(Object state)<br> at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)<br> at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)<br> at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)<br> at System.Threading.ThreadHelper.ThreadStart()<br><br><br><report xmlns="<a href=" http: rel="nofollow" target="_blank">http://emclient.com/ns/report"><br> <product><br> <name>eM Client</name><br> <version>7.0.27943.0</version><br> </product><br> <silent>false</silent><br> <environment><br> <osversion>Microsoft Windows NT 10.0.14393.0</osversion><br> <frameworkversion>4.0.30319.42000</frameworkversion><br> </environment><br> <exception><br> <type>System.Reflection.TargetInvocationException</type><br> <message>Exception has been thrown by the target of an invocation.</message><br> <source>mscorlib</source><br> <stack><br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100667731</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.RuntimeMethodHandle</type><br> <name>InvokeMethod</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>target</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object[]</type><br> <name>arguments</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Signature</type><br> <name>sig</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>constructor</name><br> </parameter><br> </parameters><br> </method><br> <offset>ffffffff</offset><br> <nativeoffset>0</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100680927</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.Reflection.RuntimeMethodInfo</type><br> <name>UnsafeInvokeInternal</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>obj</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object[]</type><br> <name>parameters</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object[]</type><br> <name>arguments</name><br> </parameter><br> </parameters><br> </method><br> <offset>16</offset><br> <nativeoffset>a0</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100664795</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.Delegate</type><br> <name>DynamicInvokeImpl</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object[]</type><br> <name>args</name><br> </parameter><br> </parameters><br> </method><br> <offset>24</offset><br> <nativeoffset>75</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.Accounts.dll</modulename><br> <metadatatoken>100663556</metadatatoken><br> <assembly>MailClient.Accounts</assembly><br> <type>MailClient.Storage.Views.UIDispatcherQueue</type><br> <name>ProcessNotifications</name><br> <parameters></parameters><br> </method><br> <offset>34</offset><br> <nativeoffset>8b</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.Accounts.dll</modulename><br> <metadatatoken>100663557</metadatatoken><br> <assembly>MailClient.Accounts</assembly><br> <type>MailClient.Storage.Views.UIDispatcherQueue</type><br> <name>Dispatch</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Delegate</type><br> <name>methodDelegate</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object[]</type><br> <name>parameters</name><br> </parameter><br> </parameters><br> </method><br> <offset>81</offset><br> <nativeoffset>ef</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.Accounts.dll</modulename><br> <metadatatoken>100663545</metadatatoken><br> <assembly>MailClient.Accounts</assembly><br> <type>MailClient.Storage.Views.ItemCollectionView
2
folder_RefreshItems
mscorlib
System.Object
sender
MailClient.Storage
e
42
d9
100665497
MailClient.Accounts
MailClient.Storage.Application.ItemCollection2+<>c __DisplayClass74_0</type><br> <name><OnRefreshItems>b__ 0</name><br> <parameters></parameters><br> </method><br> <offset>d</offset><br> <nativeoffset>1d</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.Accounts.dll</modulename><br> <metadatatoken>100663989</metadatatoken><br> <assembly>MailClient.Accounts</assembly><br> <type>MailClient.Storage.Application.TaskQueue</type><br> <name><.ctor>b__4_0</name><br> <parameters></parameters><br> </method><br> <offset>51</offset><br> <nativeoffset>a8</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100678319</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.Threading.ThreadHelper</type><br> <name>ThreadStart_Context</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>state</name><br> </parameter><br> </parameters><br> </method><br> <offset>14</offset><br> <nativeoffset>9c</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100678072</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.Threading.ExecutionContext</type><br> <name>RunInternal</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Threading.ExecutionContext</type><br> <name>executionContext</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Threading.ContextCallback</type><br> <name>callback</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>state</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>preserveSyncCtx</name><br> </parameter><br> </parameters><br> </method><br> <offset>79</offset><br> <nativeoffset>c1</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100678071</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.Threading.ExecutionContext</type><br> <name>Run</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Threading.ExecutionContext</type><br> <name>executionContext</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Threading.ContextCallback</type><br> <name>callback</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>state</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>preserveSyncCtx</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>15</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100678070</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.Threading.ExecutionContext</type><br> <name>Run</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Threading.ExecutionContext</type><br> <name>executionContext</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Threading.ContextCallback</type><br> <name>callback</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>state</name><br> </parameter><br> </parameters><br> </method><br> <offset>2b</offset><br> <nativeoffset>40</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100678321</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.Threading.ThreadHelper</type><br> <name>ThreadStart</name><br> <parameters></parameters><br> </method><br> <offset>8</offset><br> <nativeoffset>43</nativeoffset><br> <br> </stack><br> <data><br> <dispatchertype>null</dispatchertype><br> </data><br> <inner><br> <exception><br> <type>System.NullReferenceException</type><br> <message>Object reference not set to an instance of an object.</message><br> <source>MailClient.Accounts</source><br> <stack><br> <frame> <br> <method><br> <modulename>MailClient.Accounts.dll</modulename><br> <metadatatoken>100663475</metadatatoken><br> <assembly>MailClient.Accounts</assembly><br> <type>MailClient.Storage.Views.BaseCollectionView
1
UpdateAndNotify
MailClient.Collections
changeEvent
34a
111a
MailClient.Storage.Views.AggregatedCollectionView1[MailClient.Storage.Application.Mail.MailItem]Void itemCollectionViewAdapter_CollectionChanged(System.Object, MailClient.Collections.NotifyCollectionChangedEventArgs
1[MailClient.Storage.Application.Mail.MailItem])
null
MailClient.exe
C:\Program Files (x86)\eM Client\MailClient.exe
MailClient.exe
MailClient.exe
7.0.27943.0
eM Client
eM Client
7.0.27943.0
False
False
False
False
False
Language Neutral
ntdll.dll
C:\WINDOWS\SYSTEM32\ntdll.dll
ntdll.dll
ntdll.dll.mui
10.0.14393.206 (rs1_release.160915-0644)
NT Layer DLL
Microsoft® Windows® Operating System
10.0.14393.206
False
False
False
False
False
English (United States)
MSCOREE.DLL
C:\WINDOWS\SYSTEM32\MSCOREE.DLL
mscoree.dll
mscoree.dll
10.0.14393.0 (rs1_release.160715-1616)
Microsoft .NET Runtime Execution Engine
10.0.14393.0
False
False
False
False
False
KERNEL32.dll
C:\WINDOWS\System32\KERNEL32.dll
kernel32
kernel32
Windows NT BASE API Client DLL
10.0.14393.206
False
False
False
False
False
KERNELBASE.dll
C:\WINDOWS\System32\KERNELBASE.dll
Kernelbase.dll
Kernelbase.dll.mui
10.0.14393.206
False
False
False
False
False
ADVAPI32.dll
C:\WINDOWS\System32\ADVAPI32.dll
advapi32.dll
advapi32.dll.mui
Advanced Windows 32 Base API
10.0.14393.0
False
False
False
False
False
msvcrt.dll
C:\WINDOWS\System32\msvcrt.dll
msvcrt.dll
msvcrt.dll
7.0.14393.0 (rs1_release.160715-1616)
Windows NT CRT DLL
7.0.14393.0
False
False
False
False
False
sechost.dll
C:\WINDOWS\System32\sechost.dll
sechost.dll
sechost.dll.mui
Host for SCM/SDDL/LSA Lookup APIs
10.0.14393.0
False
False
False
False
False
RPCRT4.dll
C:\WINDOWS\System32\RPCRT4.dll
rpcrt4.dll
rpcrt4.dll.mui
Remote Procedure Call Runtime
10.0.14393.0
False
False
False
False
False
SspiCli.dll
C:\WINDOWS\System32\SspiCli.dll
security.dll
security.dll
10.0.14393.187 (rs1_release_inmarket.160906-1818)
Security Support Provider Interface
10.0.14393.187
False
False
False
False
False
CRYPTBASE.dll
C:\WINDOWS\System32\CRYPTBASE.dll
cryptbase.dll
cryptbase.dll
Base cryptographic API DLL
10.0.14393.0
False
False
False
False
False
bcryptPrimitives.dll
C:\WINDOWS\System32\bcryptPrimitives.dll
bcryptprimitives.dll
Windows Cryptographic Primitives Library
10.0.14393.0
False
False
False
False
False
mscoreei.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
mscoreei.dll
mscoreei.dll
4.6.1586.0 built by: NETFXREL2
Microsoft® .NET Framework
4.6.1586.0
False
False
False
True
False
SHLWAPI.dll
C:\WINDOWS\System32\SHLWAPI.dll
SHLWAPI
SHLWAPI.DLL.MUI
Shell Light-weight Utility Library
10.0.14393.0
False
False
False
False
False
combase.dll
C:\WINDOWS\System32\combase.dll
COMBASE.DLL
COMBASE.DLL.MUI
Microsoft COM for Windows
10.0.14393.0
False
False
False
False
False
ucrtbase.dll
C:\WINDOWS\System32\ucrtbase.dll
ucrtbase.dll
ucrtbase.dll
Microsoft® C Runtime Library
10.0.14393.0
False
False
False
False
False
GDI32.dll
C:\WINDOWS\System32\GDI32.dll
gdi32
gdi32
GDI Client DLL
10.0.14393.206
False
False
False
False
False
gdi32full.dll
C:\WINDOWS\System32\gdi32full.dll
gdi32
gdi32
10.0.14393.447 (rs1_release_inmarket.161102-0100)
GDI Client DLL
10.0.14393.447
False
False
False
False
False
USER32.dll
C:\WINDOWS\System32\USER32.dll
user32
user32
Multi-User Windows USER API Client DLL
10.0.14393.0
False
False
False
False
False
win32u.dll
C:\WINDOWS\System32\win32u.dll
Win32u
Win32u.DLL
10.0.14393.51 (rs1_release_inmarket.160801-1836)
Win32u
10.0.14393.51
False
False
False
False
False
IMM32.DLL
C:\WINDOWS\System32\IMM32.DLL
imm32
imm32
Multi-User Windows IMM32 API Client DLL
10.0.14393.0
False
False
False
False
False
kernel.appcore.dll
C:\WINDOWS\System32\kernel.appcore.dll
kernel.appcore.dll
kernel.appcore.dll
AppModel API Host
10.0.14393.0
False
False
False
False
False
VERSION.dll
C:\WINDOWS\SYSTEM32\VERSION.dll
version
VERSION.DLL
Version Checking and File Installation Libraries
10.0.14393.0
False
False
False
False
False
clr.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
clr.dll
clr.dll
Microsoft .NET Runtime Common Language Runtime - WorkStation
4.6.1586.0
False
False
False
True
False
MSVCR120_CLR0400.dll
C:\WINDOWS\SYSTEM32\MSVCR120_CLR0400.dll
msvcr120_clr0400.dll
12.00.52512.0 built by: VSWINSERVICING
Microsoft® Visual Studio® 2013
12.00.52512.0
False
False
False
False
False
mscorlib.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\mscorlib\40571abae9422cd2ca6fafbbde1c3cdc\mscorlib.ni.dll
mscorlib.dll
mscorlib.dll
Microsoft Common Language Runtime Class Library
4.6.1586.0
False
False
False
True
False
ole32.dll
C:\WINDOWS\System32\ole32.dll
OLE32.DLL
OLE32.DLL.MUI
Microsoft OLE for Windows
10.0.14393.0
False
False
False
False
False
uxtheme.dll
C:\WINDOWS\system32\uxtheme.dll
UxTheme.dll
UxTheme.dll.mui
Microsoft UxTheme Library
10.0.14393.0
False
False
False
False
False
CRYPTSP.dll
C:\WINDOWS\SYSTEM32\CRYPTSP.dll
cryptsp.dll
cryptsp.dll
Cryptographic Service Provider API
10.0.14393.0
False
False
False
False
False
rsaenh.dll
C:\WINDOWS\system32\rsaenh.dll
rsaenh.dll
rsaenh.dll.mui
Microsoft Enhanced Cryptographic Provider
10.0.14393.0
False
False
False
False
False
bcrypt.dll
C:\WINDOWS\SYSTEM32\bcrypt.dll
bcrypt.dll
bcrypt.dll.mui
10.0.14393.0
False
False
False
False
False
System.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System\08da6b6698b412866e6910ae9b84f363\System.ni.dll
System.dll
System.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
MailClient.Mail.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.Mail\01672ae7c7afb9bd6c248780924ab646\MailClient.Mail.ni.dll
MailClient.Mail.dll
MailClient.Mail.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
HTMLEditorControl.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\HTMLEditorControl\7b9b93578cfe9955f1ee74f2f2314a05\HTMLEditorControl.ni.dll
HTMLEditorControl.dll
7.0.27943.0
HtmlEditorControl
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Collections.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.1d52ed9e#\479ec7e02599fb06f4723c1e46dd6b6e\MailClient.Collections.ni.dll
MailClient.Collections.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.ni.exe
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient\d4a5a0f1dfb8fa9993addc6694219e4e\MailClient.ni.exe
MailClient.exe
MailClient.exe
7.0.27943.0
eM Client
eM Client
7.0.27943.0
False
False
False
False
False
Language Neutral
LinqBridge.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\LinqBridge\7f81d5cca946c5ced7a0d9ae8cb0dfbb\LinqBridge.ni.dll
LinqBridge.dll
LinqBridge.dll
1.3.13216.2214
LINQBridge
LINQBridge
1.3.13216.2214
False
False
False
False
False
Language Neutral
MailClient.Accounts.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.Accounts\4dc65e8ce6b63da5433865954d81086f\MailClient.Accounts.ni.dll
7.0.27943.0
MailClient.Accounts
MailClient.Accounts
7.0.27943.0
False
False
False
False
False
Language Neutral
System.Drawing.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Drawing\c2abcda8f96d67fa6ff5665fd21dddff\System.Drawing.ni.dll
System.Drawing.dll
System.Drawing.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
System.Windows.Forms.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\c02fbf560e52a1aab432a90d4c613af4\System.Windows.Forms.ni.dll
System.Windows.Forms.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
MailClient.Storage.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.Storage\a21904592cf98145f7632ba4ab4275c5\MailClient.Storage.ni.dll
MailClient.Storage.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Common.UI.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.Common.UI\c28c14124585fc8519222d62f805b5d9\MailClient.Common.UI.ni.dll
MailClient.Common.UI.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Interop.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.Interop\37fddd51705d8ba64729fd21a24f53e8\MailClient.Interop.ni.dll
MailClient.Interop.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.ExceptionUtils.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.ad6c0f7b#\db1442980738128c9b1e3a6bdc8ed509\MailClient.ExceptionUtils.ni.dll
MailClient.ExceptionUtils.dll
1.0.0.0
1.0.0.0
False
False
False
False
False
Language Neutral
jabber-net.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\jabber-net\27833f3d684c2cedb034fd7b6c692235\jabber-net.ni.dll
jabber-net.dll
jabber-net.dll
7.0.0.3
Jabber-Net library
jabber-net
7.0.0.3
False
False
False
False
False
Language Neutral
MailClient.Protocols.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.Protocols\cbaa550ceced0640e1866b758fed6eea\MailClient.Protocols.ni.dll
MailClient.Protocols.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
Xilium.CefGlue.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\Xilium.CefGlue\2cb3d507c7b81167657634ad1b3e94f3\Xilium.CefGlue.ni.dll
Xilium.CefGlue.dll
Xilium.CefGlue.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
Microsoft.Experimental.IO.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\Microsoft.E765800fb#\7a15b1fc2ddae8c7494b6d2f936e0010\Microsoft.Experimental.IO.ni.dll
Microsoft.Experimental.IO.dll
1.0.0.3
1.0.0.3
False
False
False
False
False
Language Neutral
WinApi.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\WinApi\1087b36941fb59d72516a5da4161926c\WinApi.ni.dll
WinApi.dll
WinApi.dll
1.1.27943.0
WinApi
WinApi
1.1.27943.0
False
False
False
False
False
Language Neutral
System.Core.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Core\f6ebd52be27fe627fed0d185c6a9c0d5\System.Core.ni.dll
System.Core.dll
System.Core.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
System.Data.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Data\2b901873687e343684064998783c1f8d\System.Data.ni.dll
system.data.dll
system.data.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
System.Data.dll
C:\WINDOWS\Microsoft.Net\assembly\GAC_32\System.Data\v4.0_4.0.0.0__b77a5c561934e089\System.Data.dll
system.data.dll
system.data.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
WS2_32.dll
C:\WINDOWS\System32\WS2_32.dll
ws2_32.dll
ws2_32.dll.mui
Windows Socket 2.0 32-Bit DLL
10.0.14393.0
False
False
False
False
False
CRYPT32.dll
C:\WINDOWS\System32\CRYPT32.dll
CRYPT32.DLL
CRYPT32.DLL.MUI
Crypto API32
10.0.14393.0
False
False
False
False
False
MSASN1.dll
C:\WINDOWS\System32\MSASN1.dll
msasn1.dll
msasn1.dll
ASN.1 Runtime APIs
10.0.14393.0
False
False
False
False
False
libcef.DLL
C:\Program Files (x86)\eM Client\libcef.DLL
libcef
libcef.dll
3.2623.1422.gcb2184a
Chromium Embedded Framework (CEF) Dynamic Link Library
False
False
False
False
False
PSAPI.DLL
C:\WINDOWS\System32\PSAPI.DLL
PSAPI
PSAPI
Process Status Helper
10.0.14393.0
False
False
False
False
False
USP10.dll
C:\WINDOWS\SYSTEM32\USP10.dll
USP10.DLL
USP10.DLL
Uniscribe Unicode script processor
10.0.14393.0
False
False
False
False
False
COMDLG32.dll
C:\WINDOWS\System32\COMDLG32.dll
comdlg32
comdlg32.dll.mui
Common Dialogs DLL
10.0.14393.0
False
False
False
False
False
WINSPOOL.DRV
C:\WINDOWS\SYSTEM32\WINSPOOL.DRV
winspool.drv
winspool.drv.mui
Windows Spooler Driver
10.0.14393.0
False
False
False
False
False
shcore.dll
C:\WINDOWS\System32\shcore.dll
SHCORE
SHCORE.dll.mui
SHCORE
10.0.14393.0
False
False
False
False
False
SHELL32.dll
C:\WINDOWS\System32\SHELL32.dll
SHELL32
SHELL32.DLL.MUI
Windows Shell Common Dll
10.0.14393.0
False
False
False
False
False
cfgmgr32.dll
C:\WINDOWS\System32\cfgmgr32.dll
cfgmgr32.dll
CFGMGR32.DLL
Configuration Manager DLL
10.0.14393.0
False
False
False
False
False
COMCTL32.dll
C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.14393.447_none_89c64d28dafea4b9\COMCTL32.dll
comctl32
comctl32.DLL.MUI
6.10 (rs1_release_inmarket.161102-0100)
User Experience Controls Library
10.0.14393.447
False
False
False
False
False
windows.storage.dll
C:\WINDOWS\System32\windows.storage.dll
Windows.Storage
Windows.Storage.dll.MUI
Microsoft WinRT Storage API
10.0.14393.0
False
False
False
False
False
powrprof.dll
C:\WINDOWS\System32\powrprof.dll
POWRPROF
POWRPROF.DLL.MUI
Power Profile Helper DLL
10.0.14393.0
False
False
False
False
False
profapi.dll
C:\WINDOWS\System32\profapi.dll
PROFAPI.DLL
PROFAPI.DLL
User Profile Basic API
10.0.14393.0
False
False
False
False
False
OLEAUT32.dll
C:\WINDOWS\System32\OLEAUT32.dll
OLEAUT32.DLL
OLEAUT32.DLL
OLEAUT32.DLL
10.0.14393.447
False
False
False
False
False
msvcp_win.dll
C:\WINDOWS\System32\msvcp_win.dll
msvcp_win.dll
msvcp_win.dll
10.0.14393.0
False
False
False
False
False
WINHTTP.dll
C:\WINDOWS\SYSTEM32\WINHTTP.dll
winhttp.dll
winhttp.dll.mui
Windows HTTP Services
10.0.14393.0
False
False
False
False
False
USERENV.dll
C:\WINDOWS\SYSTEM32\USERENV.dll
userenv
userenv.dll.mui
Userenv
10.0.14393.0
False
False
False
False
False
urlmon.dll
C:\WINDOWS\SYSTEM32\urlmon.dll
UrlMon.dll
UrlMon.dll.mui
11.00.14393.0 (rs1_release.160715-1616)
OLE32 Extensions for Win32
Internet Explorer
11.00.14393.0
False
False
False
False
False
dhcpcsvc.DLL
C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL
dhcpcsvc.dll
dhcpcsvc.dll.mui
DHCP Client Service
10.0.14393.0
False
False
False
False
False
NSI.dll
C:\WINDOWS\System32\NSI.dll
nsi.dll
nsi.dll
NSI User-mode interface DLL
10.0.14393.0
False
False
False
False
False
WTSAPI32.dll
C:\WINDOWS\SYSTEM32\WTSAPI32.dll
wtsapi32.dll
wtsapi32.dll
Windows Remote Desktop Session Host Server SDK APIs
10.0.14393.0
False
False
False
False
False
OLEACC.dll
C:\WINDOWS\SYSTEM32\OLEACC.dll
OLEACC
OLEACC.DLL
7.2.14393.206 (rs1_release.160915-0644)
Active Accessibility Core Component
10.0.14393.206
False
False
False
False
False
Language Neutral
WINMM.dll
C:\WINDOWS\SYSTEM32\WINMM.dll
winmm.dll
WINMM.DLL.MUI
MCI API DLL
10.0.14393.0
False
False
False
False
False
Secur32.dll
C:\WINDOWS\SYSTEM32\Secur32.dll
secur32.dll
secur32.dll
10.0.14393.0
False
False
False
False
False
IPHLPAPI.DLL
C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL
iphlpapi.dll
iphlpapi.dll.mui
IP Helper API
10.0.14393.0
False
False
False
False
False
iertutil.dll
C:\WINDOWS\SYSTEM32\iertutil.dll
IeRtUtil.dll
IeRtUtil.dll.mui
Run time utility for Internet Explorer
Internet Explorer
11.00.14393.0
False
False
False
False
False
WINMMBASE.dll
C:\WINDOWS\SYSTEM32\WINMMBASE.dll
winmmbase.dll
WINMMbase.DLL.MUI
Base Multimedia Extension API DLL
10.0.14393.0
False
False
False
False
False
System.Configuration.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Configuration\aa9c29b70b4cceab890eb841f89d73e9\System.Configuration.ni.dll
System.Configuration.dll
4.6.1586.0
False
False
False
True
False
System.Xml.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Xml\7532301b00fac8def2f526ca8b480e11\System.Xml.ni.dll
System.Xml.dll
System.Xml.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
comctl32.dll
C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.14393.447_none_5507ded2cb4f7f4c\comctl32.dll
COMCTL32
COMCTL32.DLL.MUI
5.82 (rs1_release_inmarket.161102-0100)
Common Controls Library
10.0.14393.447
False
False
False
False
False
dwmapi.dll
C:\WINDOWS\system32\dwmapi.dll
dwmapi.dll
dwmapi.dll.mui
Microsoft Desktop Window Manager API
10.0.14393.0
False
False
False
False
False
MSCTF.dll
C:\WINDOWS\System32\MSCTF.dll
MSCTF
MSCTF.DLL.MUI
MSCTF Server DLL
10.0.14393.0
False
False
False
False
False
gdiplus.dll
C:\WINDOWS\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.14393.321_none_baab3cb4359688b4\gdiplus.dll
gdiplus
gdiplus
10.0.14393.321 (rs1_release_inmarket.161004-2338)
Microsoft GDI+
10.0.14393.321
False
False
False
False
False
System.Runtime.Remoting.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Runt73a1fc9d#\272d1cf3a7cbd4cd648a2ff2d7a8889a\System.Runtime.Remoting.ni.dll
System.Runtime.Remoting.dll
Microsoft .NET Runtime Object Remoting
4.6.1586.0
False
False
False
True
False
mswsock.dll
C:\WINDOWS\system32\mswsock.dll
mswsock.dll
mswsock.dll.mui
Microsoft Windows Sockets 2.0 Service Provider
10.0.14393.0
False
False
False
False
False
diasymreader.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\diasymreader.dll
diasymreader.dll
diasymreader.dll
14.6.1586.0 built by: NETFXREL2
Dia based SymReader
Microsoft® Visual Studio® 12 CTP
14.6.1586.0
False
False
False
False
False
PROPSYS.dll
C:\WINDOWS\System32\PROPSYS.dll
propsys.dll
propsys.dll.mui
Microsoft Property System
Windows® Search
7.0.14393.0
False
False
False
False
False
clbcatq.dll
C:\WINDOWS\System32\clbcatq.dll
CLBCATQ.DLL
CLBCATQ.DLL
2001.12.10941.16384 (rs1_release.160715-1616)
COM+ Configuration Catalog
10.0.14393.0
False
False
False
False
False
edputil.dll
C:\WINDOWS\System32\edputil.dll
EDPUTIL.DLL
EDPUTIL.DLL.MUI
EDP util
10.0.14393.0
False
False
False
False
False
System.Data.SQLite.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Data.SQLite\2a9f4a25337db79856d6212e3965e2f4\System.Data.SQLite.ni.dll
System.Data.SQLite.dll
1.0.84.2
System.Data.SQLite Core
System.Data.SQLite
1.0.84.2
False
False
False
False
False
Language Neutral
sqlite3.dll
C:\Program Files (x86)\eM Client\SQLite\x86\sqlite3.dll
False
False
False
False
False
Microsoft.Search.Interop.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\Microsoft.Sd25cd4a4#\e38446ad2c49fc030ff23f17d897dde8\Microsoft.Search.Interop.ni.dll
Microsoft.Search.Interop.dll
1.0.0.0
Assembly imported from type library ‘SearchAPILib’.
1.0.0.0
False
False
False
False
False
Invariant Language (Invariant Country)
System.Transactions.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Transactions\4f886295844dc43b0ff606c4caaeb80e\System.Transactions.ni.dll
system.transactions.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
System.Transactions.dll
C:\WINDOWS\Microsoft.Net\assembly\GAC_32\System.Transactions\v4.0_4.0.0.0__b77a5c561934e089\System.Transactions.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
System.EnterpriseServices.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Ente96d83b35#\f9888bcb8ac4e66f7fdef076669ce50c\System.EnterpriseServices.ni.dll
System.EnterpriseServices.dll
Microsoft .NET Services Support Infrastructure
4.6.1586.0
False
False
False
True
False
System.EnterpriseServices.Wrapper.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Ente96d83b35#\f9888bcb8ac4e66f7fdef076669ce50c\System.EnterpriseServices.Wrapper.dll
Microsoft .NET Services Native Thunks
4.6.1586.0
False
False
False
True
False
C:\WINDOWS\Microsoft.Net\assembly\GAC_32\System.EnterpriseServices\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.Wrapper.dll
4.6.1586.0
False
False
False
True
False
MailClient.Threading.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.Threading\e2fd6c0f2ac0b21683298f6dbf2a8790\MailClient.Threading.ni.dll
MailClient.Threading.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
clrjit.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll
clrjit.dll
clrjit.dll
Microsoft .NET Runtime Just-In-Time Compiler
4.6.1586.0
False
False
False
True
False
MailClient.Streams.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.Streams\2fb5ac0a0311a3b23ae464f787bd4f4c\MailClient.Streams.ni.dll
MailClient.Streams.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Storage.Mail.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.1fd7a4e5#\c95269d082a905c0c30cc3d78cf2371a\MailClient.Storage.Mail.ni.dll
MailClient.Storage.Mail.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Storage.Folders.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.b2c914c9#\0f8d87184053bff3a5b8bd5152ea6097\MailClient.Storage.Folders.ni.dll
MailClient.Storage.Folders.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Commands.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.Commands\d05b029fcb8c65b2f456f536c83fdb13\MailClient.Commands.ni.dll
MailClient.Commands.dll
7.0.27943.0
MailClient.Commands
MailClient.Commands
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Storage.Attachment.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.5331ec95#\1ab9c28a6c831a9cef1a70fc8ed3688e\MailClient.Storage.Attachment.ni.dll
MailClient.Storage.Attachment.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Storage.Schedule.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.6df617c9#\b25456f7600e7e25c654434a4739d60a\MailClient.Storage.Schedule.ni.dll
MailClient.Storage.Schedule.dll
7.0.27943.0
MailClient.Storage.Objects
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Storage.Contact.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.f2c61d2c#\bfa9def18527d5dd246ae4880956633d\MailClient.Storage.Contact.ni.dll
MailClient.Storage.Contact.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Storage.IM.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.9a79bc48#\d0c09bf7ba0ab1852e2dc7c12d9fac4b\MailClient.Storage.IM.ni.dll
MailClient.Storage.IM.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Schedule.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.Schedule\68b9499434a4bc835f17e670f3927786\MailClient.Schedule.ni.dll
MailClient.Schedule.dll
7.0.27943.0
MailClient.Objects
MailClient.Objects
7.0.27943.0
False
False
False
False
False
Language Neutral
SystemCoreTimeZone.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\SystemCoreTimeZone\309dbc6caddf5bb0bc9913d80198219a\SystemCoreTimeZone.ni.dll
SystemCoreTimeZone.dll
1.0.0.4
SystemCoreTimeZone
SystemCoreTimeZone
1.0.0.4
False
False
False
False
False
Language Neutral
MailClient.Storage.Category.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.4824fbfc#\6c5a7b213a48e9ef69e9e1c0d3883a6a\MailClient.Storage.Category.ni.dll
MailClient.Storage.Category.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Storage.Certificate.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.d8481e79#\3e43527c6481d7f0e3910e9cc82a74bb\MailClient.Storage.Certificate.ni.dll
MailClient.Storage.Certificate.dll
7.0.27943.0
MailClient.Storage.Template
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Storage.Security.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.c1d859fa#\51f06925f7cdeef23ace40a27f4af276\MailClient.Storage.Security.ni.dll
MailClient.Storage.Security.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Storage.Snippet.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.c3eb0b89#\992dae0c39c2ada9f9e7d7e2bfbf4824\MailClient.Storage.Snippet.ni.dll
MailClient.Storage.Snippet.dll
7.0.27943.0
MailClient.Storage.Signature
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Storage.Template.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.319ca19c#\88136a8074371be1df7176deb8ef111e\MailClient.Storage.Template.ni.dll
MailClient.Storage.Template.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.IM.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.IM\6ab4ec73d60d238722e33759f6084a6e\MailClient.IM.ni.dll
MailClient.IM.dll
MailClient.IM.dll
7.0.27943.0
MailClient.IM
MailClient.IM
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Storage.Rule.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.1fe73d22#\c4b76a4141f79a0311c6b46d00e0a56f\MailClient.Storage.Rule.ni.dll
MailClient.Storage.Rule.dll
7.0.27943.0
MailClient.Storage.Widget
7.0.27943.0
False
False
False
False
False
Language Neutral
NLAapi.dll
C:\WINDOWS\system32\NLAapi.dll
nlaapi.dll
nlaapi.dll
Network Location Awareness 2
10.0.14393.0
False
False
False
False
False
audioses.dll
C:\WINDOWS\system32\audioses.dll
AudioSession
AudioSes.Dll.MUI
Audio Session
10.0.14393.0
False
False
False
False
False
MMDevAPI.DLL
C:\WINDOWS\system32\MMDevAPI.DLL
MMDeviceAPI
MMDevAPI.Dll.MUI
MMDevice API
10.0.14393.0
False
False
False
False
False
wintypes.dll
C:\WINDOWS\SYSTEM32\wintypes.dll
Windows Base Types DLL
WinTypes.dll.mui
10.0.14393.0
False
False
False
False
False
DEVOBJ.dll
C:\WINDOWS\system32\DEVOBJ.dll
devinfoset.dll
devinfoset.DLL
Device Information Set DLL
10.0.14393.0
False
False
False
False
False
dhcpcsvc6.DLL
C:\WINDOWS\SYSTEM32\dhcpcsvc6.DLL
dhcpcsvc6.dll
dhcpcsvc6.dll.mui
DHCPv6 Client
10.0.14393.0
False
False
False
False
False
SETUPAPI.dll
C:\WINDOWS\System32\SETUPAPI.dll
SETUPAPI.DLL
SETUPAPI.DLL.MUI
Windows Setup API
10.0.14393.0
False
False
False
False
False
WINTRUST.dll
C:\WINDOWS\System32\WINTRUST.dll
WINTRUST.DLL
WINTRUST.DLL
10.0.14393.351 (rs1_release_inmarket.161014-1755)
Microsoft Trust Verification APIs
10.0.14393.351
False
False
False
False
False
DWrite.dll
C:\WINDOWS\SYSTEM32\DWrite.dll
DWrite
DWrite
Microsoft DirectX Typography Services
10.0.14393.0
False
False
False
False
False
Accessibility.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\Accessibility\3cc2f32ea79d7774da421d9d8f339db8\Accessibility.ni.dll
UNKNOWN_FILE
UNKNOWN_FILE
.NET Framework
4.6.1586.0
False
False
False
True
False
WindowsCodecs.dll
C:\WINDOWS\SYSTEM32\WindowsCodecs.dll
WindowsCodecs
WindowsCodecs
Microsoft Windows Codecs Library
10.0.14393.206
False
False
False
False
False
MailClient.Attachment.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.ff7bbfa2#\b78f7303721488d4e0acfc18ba25dab0\MailClient.Attachment.ni.dll
MailClient.Attachment.dll
0.0.0.0
0.0.0.0
False
False
False
False
False
Language Neutral
MailClient.Contact.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.Contact\bacab9f84c1d3e33f6af144878448518\MailClient.Contact.ni.dll
MailClient.Contact.dll
7.0.27943.0
MailClient.Contact
MailClient.Contact
7.0.27943.0
False
False
False
False
False
Language Neutral
dataexchange.dll
C:\WINDOWS\system32\dataexchange.dll
DataExchange
DataExchange.dll
Data exchange
10.0.14393.206
False
False
False
False
False
dcomp.dll
C:\WINDOWS\system32\dcomp.dll
dcomp.dll
dcomp.dll.mui
Microsoft DirectComposition Library
10.0.14393.0
False
False
False
False
False
d3d11.dll
C:\WINDOWS\system32\d3d11.dll
D3D11.dll
D3D11.dll
Direct3D 11 Runtime
10.0.14393.351
False
False
False
False
False
dxgi.dll
C:\WINDOWS\system32\dxgi.dll
dxgi.dll
dxgi.dll
DirectX Graphics Infrastructure
10.0.14393.0
False
False
False
False
False
twinapi.appcore.dll
C:\WINDOWS\system32\twinapi.appcore.dll
twinapi.appcore
twinapi.appcore.dll.mui
twinapi.appcore
10.0.14393.0
False
False
False
False
False
Xilium.CefGlue.WindowsForms.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\Xilium.CefG0f485e28#\b90f61f277d897fdc30b1cd977c721cb\Xilium.CefGlue.WindowsForms.ni.dll
Xilium.CefGlue.WindowsForms.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
napinsp.dll
C:\WINDOWS\system32\napinsp.dll
napinsp.dll
napinsp.dll.mui
E-mail Naming Shim Provider
10.0.14393.0
False
False
False
False
False
pnrpnsp.dll
C:\WINDOWS\system32\pnrpnsp.dll
pnrpnsp.dll
pnrpnsp.dll.mui
PNRP Name Space Provider
10.0.14393.0
False
False
False
False
False
DNSAPI.dll
C:\WINDOWS\SYSTEM32\DNSAPI.dll
dnsapi
dnsapi
DNS Client API DLL
10.0.14393.0
False
False
False
False
False
winrnr.dll
C:\WINDOWS\System32\winrnr.dll
winrnr
winrnr
LDAP RnR Provider DLL
10.0.14393.0
False
False
False
False
False
Microsoft.VisualBasic.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\Microsoft.V9921e851#\02386c57c46556747a75089068a31af0\Microsoft.VisualBasic.ni.dll
Microsoft.VisualBasic.DLL
Visual Basic Runtime Library
14.6.1586.0
False
False
False
True
False
MailClient.VObject.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.VObject\3c2533ea8e0211a49c519dec442f03a1\MailClient.VObject.ni.dll
MailClient.VObject.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
WINSTA.dll
C:\WINDOWS\SYSTEM32\WINSTA.dll
winsta
winsta.dll
Winstation Library
10.0.14393.0
False
False
False
False
False
directmanipulation.dll
C:\WINDOWS\system32\directmanipulation.dll
directmanipulation.dll.mui
Microsoft Direct Manipulation Component
10.0.14393.0
False
False
False
False
False
atlthunk.dll
C:\WINDOWS\SYSTEM32\atlthunk.dll
atlthunk.dll
atlthunk.dll
atlthunk.dll
10.0.14393.0
False
False
False
False
False
WindowsAPICodePack.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\WindowsAPICodePack\b16279255784ced1744fabb31313daba\WindowsAPICodePack.ni.dll
WindowsAPICodePack.dll
1.0.1.0
WindowsAPICodePack
WindowsAPICodePack
1.0.1.0
False
False
False
False
False
Language Neutral
WINNSI.DLL
C:\WINDOWS\SYSTEM32\WINNSI.DLL
winnsi.dll
winnsi.dll
Network Store Information RPC interface
10.0.14393.0
False
False
False
False
False
LINKINFO.dll
C:\WINDOWS\System32\LINKINFO.dll
LINKINFO
LINKINFO.DLL
Windows Volume Tracking
10.0.14393.0
False
False
False
False
False
Bcp47Langs.dll
C:\WINDOWS\System32\Bcp47Langs.dll
BCP47Lang.dll
BCP47Lang.dll
BCP47 Language Classes
10.0.14393.0
False
False
False
False
False
ntshrui.dll
C:\WINDOWS\System32\ntshrui.dll
ntshrui
ntshrui.dll.mui
Shell extensions for sharing
10.0.14393.0
False
False
False
False
False
srvcli.dll
C:\WINDOWS\System32\srvcli.dll
SRVCLI.DLL
SRVCLI.DLL
Server Service Client DLL
10.0.14393.0
False
False
False
False
False
cscapi.dll
C:\WINDOWS\SYSTEM32\cscapi.dll
cscapi.dll
cscapi.dll
Offline Files Win32 API
10.0.14393.0
False
False
False
False
False
ntmarta.dll
C:\WINDOWS\SYSTEM32\ntmarta.dll
ntmarta.dll
ntmarta.dll.mui
Windows NT MARTA provider
10.0.14393.0
False
False
False
False
False
MailClient.Sasl.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.Sasl\57c43e06e4105185d97de1fa4f13d703\MailClient.Sasl.ni.dll
MailClient.Sasl.dll
MailClient.Sasl.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Imap.Base.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.Imap.Base\10eeb00b0fc8bd78f50cd37c8cc7deac\MailClient.Imap.Base.ni.dll
MailClient.Imap.Base.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
rasadhlp.dll
C:\Windows\System32\rasadhlp.dll
rasadhlp.dll
rasadhlp.dll
Remote Access AutoDial Helper
10.0.14393.0
False
False
False
False
False
fwpuclnt.dll
C:\WINDOWS\System32\fwpuclnt.dll
fwpuclnt.dll
fwpuclnt.dll.mui
FWP/IPsec User-Mode API
10.0.14393.0
False
False
False
False
False
schannel.dll
C:\WINDOWS\System32\schannel.dll
schannel.dll
schannel.dll.mui
TLS / SSL Security Provider
10.0.14393.0
False
False
False
False
False
mskeyprotect.dll
C:\WINDOWS\SYSTEM32\mskeyprotect.dll
mskeyprotect.dll
mskeyprotect.dll.mui
Microsoft Key Protection Provider
10.0.14393.0
False
False
False
False
False
ncrypt.dll
C:\WINDOWS\SYSTEM32\ncrypt.dll
ncrypt.dll
ncrypt.dll.mui
Windows NCrypt Router
10.0.14393.0
False
False
False
False
False
NTASN1.dll
C:\WINDOWS\SYSTEM32\NTASN1.dll
ntasn1.dll
ntasn1.dll.mui
Microsoft ASN.1 API
10.0.14393.0
False
False
False
False
False
ncryptsslp.dll
C:\WINDOWS\system32\ncryptsslp.dll
ncryptsslp.dll
ncryptsslp.dll
Microsoft SChannel Provider
10.0.14393.0
False
False
False
False
False
mscms.dll
C:\WINDOWS\SYSTEM32\mscms.dll
MSCMS.DLL
MSCMS.DLL.MUI
Microsoft Color Matching System DLL
10.0.14393.0
False
False
False
False
False
MailClient.HtmlConversion.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.2d2de33e#\a6e2c2ce679ca60df8e30e94c2819150\MailClient.HtmlConversion.ni.dll
MailClient.HtmlConversion.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.Protocols.Exchange.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\MailClient.d5b8df6b#\ee563b0e937f12cf1f5248437b7c606c\MailClient.Protocols.Exchange.ni.dll
MailClient.Protocols.Exchange.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
IvanAkcheurov.NClassify.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\IvanAkcheurda66b2d7#\0781454b7d1e5281dc3adf2e7cfae42c\IvanAkcheurov.NClassify.ni.dll
IvanAkcheurov.NClassify.dll
0.2.1.1
NTextCat
0.2.1.1
False
False
False
False
False
Language Neutral
IvanAkcheurov.NTextCat.Lib.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\IvanAkcheur7ace2bcd#\63fe480d67867aa651feedbaaaeb0c55\IvanAkcheurov.NTextCat.Lib.ni.dll
IvanAkcheurov.NTextCat.Lib.dll
0.2.1.1
IvanAkcheurov.NTextCatLib
NTextCat
0.2.1.1
False
False
False
False
False
Language Neutral
SgmlReader.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\SgmlReader\519f3748886bb73eea037ef50a483563\SgmlReader.ni.dll
SgmlReader.dll
SgmlReader.dll
7.0.27943.0
SgmlReader
SgmlReader
7.0.27943.0
False
False
False
False
False
Language Neutral
thumbcache.dll
C:\Windows\System32\thumbcache.dll
thumbcache.dll
thumbcache.dll.mui
Microsoft Thumbnail Cache
10.0.14393.0
False
False
False
False
False
MrmCoreR.dll
C:\Windows\System32\MrmCoreR.dll
MrmCore
MrmCore.dll.mui
Microsoft Windows MRM
10.0.14393.0
False
False
False
False
False
policymanager.dll
C:\WINDOWS\SYSTEM32\policymanager.dll
PolicyManager.dll
PolicyManager.dll
Policy Manager DLL
10.0.14393.0
False
False
False
False
False
msvcp110_win.dll
C:\WINDOWS\System32\msvcp110_win.dll
msvcp110_win.dll
msvcp110_win.dll
Microsoft® STL110 C++ Runtime Library
10.0.14393.0
False
False
False
False
False
explorerframe.dll
C:\WINDOWS\system32\explorerframe.dll
ExplorerFrame
ExplorerFrame.dll.mui
ExplorerFrame
10.0.14393.0
False
False
False
False
False
ActXPrxy.dll
C:\Windows\System32\ActXPrxy.dll
ActXPrxy.dll
ActXPrxy.dll
ActiveX Interface Marshaling Library
10.0.14393.0
False
False
False
False
False
wkscli.dll
C:\WINDOWS\System32\wkscli.dll
WKSCLI.DLL
WKSCLI.DLL
Workstation Service Client DLL
10.0.14393.0
False
False
False
False
False
netutils.dll
C:\WINDOWS\System32\netutils.dll
NETUTILS.DLL
NETUTILS.DLL
Net Win32 API Helpers DLL
10.0.14393.0
False
False
False
False
False
provsvc.dll
C:\WINDOWS\System32\provsvc.dll
provsvc
provsvc.dll.mui
Windows HomeGroup
10.0.14393.0
False
False
False
False
False
IconCodecService.dll
C:\WINDOWS\system32\IconCodecService.dll
ICONCODESERVICE.DLL
ICONCODESERVICE.DLL
Converts a PNG part of the icon to a legacy bmp icon
10.0.14393.0
False
False
False
False
False
pcacli.dll
C:\WINDOWS\System32\pcacli.dll
Program Compatibility Assistant Client Module
10.0.14393.0
False
False
False
False
False
MPR.dll
C:\WINDOWS\System32\MPR.dll
mpr.dll
mpr.dll.mui
Multiple Provider Router DLL
10.0.14393.0
False
False
False
False
False
sfc_os.dll
C:\WINDOWS\System32\sfc_os.dll
sfc_os.dll
sfc_os.dll
Windows File Protection
10.0.14393.0
False
False
False
False
False
DEVRTL.dll
C:\WINDOWS\SYSTEM32\DEVRTL.dll
DEVRTL.dll
DEVRTL.DLL
Device Management Run Time Library
10.0.14393.0
False
False
False
False
False
QuartzTypeLib.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\QuartzTypeLib\db75c640f101ed38f8453b9cfc7b6cef\QuartzTypeLib.ni.dll
QuartzTypeLib
QuartzTypeLib.dll
1.0.0.0
Assembly imported from type library ‘QuartzTypeLib’.
1.0.0.0
False
False
False
False
False
quartz.dll
C:\Windows\System32\quartz.dll
Quartz.dll
Quartz.dll.mui
DirectShow Runtime.
10.0.14393.0
False
False
False
False
False
devenum.dll
C:\Windows\System32\devenum.dll
devenum.dll
devenum.dll.mui
Device enumeration.
10.0.14393.0
False
False
False
False
False
vsfilter.dll
C:\Program Files (x86)\K-Lite Codec Pack\Filters\vsfilter.dll
VSFilter
VSFilter.dll
1.7.8.109 (4483f3b) (develop)
VobSub & TextSub filter for DirectShow/VirtualDub/Avisynth
VSFilter
False
False
False
False
False
WININET.dll
C:\WINDOWS\SYSTEM32\WININET.dll
wininet.dll
wininet.dll.mui
11.00.14393.447 (rs1_release_inmarket.161102-0100)
Internet Extensions for Win32
Internet Explorer
11.00.14393.447
False
False
False
False
False
clm4splt.ax
C:\Program Files (x86)\CyberLink\PowerDVD\NavFilter\clm4splt.ax
CyberLink MPEG-4 Splitter
clm4splt.ax
1.0.2803
1.0.2803
False
False
False
False
False
LAVSplitter.ax
C:\Program Files (x86)\K-Lite Codec Pack\Filters\LAV\LAVSplitter.ax
LAVSplitter.ax
LAVSplitter.ax
0.64.0.26-git
LAV Splitter - DirectShow Media Splitter
LAV Splitter
0.64.0.26-git
False
False
False
False
False
libbluray.dll
C:\Program Files (x86)\K-Lite Codec Pack\Filters\LAV\libbluray.dll
False
False
False
False
False
avformat-lav-56.dll
C:\Program Files (x86)\K-Lite Codec Pack\Filters\LAV\avformat-lav-56.dll
libavformat
avformat-lav-56.dll
56.26.101
FFmpeg container format library
FFmpeg
git-2015-03-24-e6b6837
False
False
False
False
False
avutil-lav-54.dll
C:\Program Files (x86)\K-Lite Codec Pack\Filters\LAV\avutil-lav-54.dll
libavutil
avutil-lav-54.dll
54.20.100
FFmpeg utility library
FFmpeg
False
False
False
False
False
avcodec-lav-56.dll
C:\Program Files (x86)\K-Lite Codec Pack\Filters\LAV\avcodec-lav-56.dll
libavcodec
avcodec-lav-56.dll
56.29.100
FFmpeg codec library
FFmpeg
False
False
False
False
False
avresample-lav-2.dll
C:\Program Files (x86)\K-Lite Codec Pack\Filters\LAV\avresample-lav-2.dll
libavresample
2.1.0
Libav audio resampling library
FFmpeg
False
False
False
False
False
System.Web.Services.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Web.Services\d9f0d90129b825fc127c24e28333f5b3\System.Web.Services.ni.dll
System.Web.Services.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
wdmaud.drv
C:\WINDOWS\SYSTEM32\wdmaud.drv
wdmaud.drv
wdmaud.drv.mui
Winmm audio system driver
10.0.14393.0
False
False
False
False
False
ksuser.dll
C:\WINDOWS\SYSTEM32\ksuser.dll
ksuser.dll
ksuser.dll
User CSA Library
10.0.14393.0
False
False
False
False
False
Language Neutral
AVRT.dll
C:\WINDOWS\SYSTEM32\AVRT.dll
avrt.dll
avrt.dll
Multimedia Realtime Runtime
10.0.14393.0
False
False
False
False
False
msacm32.drv
C:\WINDOWS\SYSTEM32\msacm32.drv
Microsoft Sound Mapper
msacm32.acm.mui
10.0.14393.0
False
False
False
False
False
MSACM32.dll
C:\WINDOWS\SYSTEM32\MSACM32.dll
Microsoft ACM Audio Filter
msfltr32.acm.mui
10.0.14393.0
False
False
False
False
False
midimap.dll
C:\WINDOWS\SYSTEM32\midimap.dll
midimap
midimap.dll.mui
Microsoft MIDI Mapper
10.0.14393.0
False
False
False
False
False
DSOUND.DLL
C:\WINDOWS\SYSTEM32\DSOUND.DLL
DirectSound
dsound.dll.mui
DirectSound
10.0.14393.0
False
False
False
False
False
apphelp.dll
C:\WINDOWS\System32\apphelp.dll
Apphelp
Apphelp
Application Compatibility Client Library
10.0.14393.0
False
False
False
False
False
PhotoMetadataHandler.dll
C:\WINDOWS\SYSTEM32\PhotoMetadataHandler.dll
Photo Metadata Handler
10.0.14393.0
False
False
False
False
False
NHunspell.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\NHunspell\431118ee8a7dc735805342fb595dab82\NHunspell.ni.dll
NHunspell.dll
NHunspell.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
ExCSS.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\ExCSS\804ad1b76e0e86a099306835e7eb351c\ExCSS.ni.dll
ExCSS.dll
ExCSS.dll
1.0.0.0
ExCSS
ExCSS
1.0.0.0
False
False
False
False
False
Language Neutral
RtfToHtml.ni.dll
C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\RtfToHtml\73b75e7168f7ea6cb3cc1e8dbb914403\RtfToHtml.ni.dll
RtfToHtml.dll
RtfToHtml.dll
1.0.0.1
RtfToHtml
RtfToHtml
1.0.0.1
False
False
False
False
False
Language Neutral
Hunspellx86.dll
C:\Program Files (x86)\eM Client\Hunspellx86.dll
Hunspell
1,2,5554,16953
Hunspell Native Code DLL
NHunspell Spell Checker
1.2.5554.16953
False
False
False
False
False
German (Germany)
twinui.dll
C:\WINDOWS\system32\twinui.dll
TWINUI
TWINUI.dll.mui
TWINUI
10.0.14393.0
False
False
False
False
False
twinui.appcore.dll
C:\WINDOWS\System32\twinui.appcore.dll
TWINUI.APPCORE
TWINUI.APPCORE.dll.MUI
TWINUI.APPCORE
10.0.14393.0
False
False
False
False
False
execmodelproxy.dll
C:\WINDOWS\system32\execmodelproxy.dll
ExecModelProxy
ExecModelProxy.dll
ExecModelProxy
10.0.14393.0
False
False
False
False
False
Windows.UI.dll
C:\Windows\System32\Windows.UI.dll
Windows Runtime UI Foundation DLL
Windows.UI.dll.MUI
10.0.14393.0
False
False
False
False
False
1 changeEvent)
1 e)
at MailClient.Storage.Application.ItemCollection2.<>c__DisplayClass74_0.<onrefreshitems>b__0()<br> at MailClient.Storage.Application.TaskQueue.<.ctor>b__4_0()<br> at System.Threading.ThreadHelper.ThreadStart_Context(Object state)<br> at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)<br> at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)<br> at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)<br> at System.Threading.ThreadHelper.ThreadStart()<br><br><br><report xmlns="<a href=" http: rel="nofollow" target="_blank">http://emclient.com/ns/report"><br> <product><br> <name>eM Client</name><br> <version>7.0.27943.0</version><br> </product><br> <silent>false</silent><br> <environment><br> <osversion>Microsoft Windows NT 10.0.14393.0</osversion><br> <frameworkversion>4.0.30319.42000</frameworkversion><br> </environment><br> <exception><br> <type>System.Reflection.TargetInvocationException</type><br> <message>Exception has been thrown by the target of an invocation.</message><br> <source>mscorlib</source><br> <stack><br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100667731</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.RuntimeMethodHandle</type><br> <name>InvokeMethod</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>target</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object[]</type><br> <name>arguments</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Signature</type><br> <name>sig</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>constructor</name><br> </parameter><br> </parameters><br> </method><br> <offset>ffffffff</offset><br> <nativeoffset>0</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100680927</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.Reflection.RuntimeMethodInfo</type><br> <name>UnsafeInvokeInternal</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>obj</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object[]</type><br> <name>parameters</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object[]</type><br> <name>arguments</name><br> </parameter><br> </parameters><br> </method><br> <offset>16</offset><br> <nativeoffset>a0</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100664795</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.Delegate</type><br> <name>DynamicInvokeImpl</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object[]</type><br> <name>args</name><br> </parameter><br> </parameters><br> </method><br> <offset>24</offset><br> <nativeoffset>75</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.Accounts.dll</modulename><br> <metadatatoken>100663556</metadatatoken><br> <assembly>MailClient.Accounts</assembly><br> <type>MailClient.Storage.Views.UIDispatcherQueue</type><br> <name>ProcessNotifications</name><br> <parameters></parameters><br> </method><br> <offset>34</offset><br> <nativeoffset>8b</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.Accounts.dll</modulename><br> <metadatatoken>100663557</metadatatoken><br> <assembly>MailClient.Accounts</assembly><br> <type>MailClient.Storage.Views.UIDispatcherQueue</type><br> <name>Dispatch</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Delegate</type><br> <name>methodDelegate</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object[]</type><br> <name>parameters</name><br> </parameter><br> </parameters><br> </method><br> <offset>81</offset><br> <nativeoffset>ef</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.Accounts.dll</modulename><br> <metadatatoken>100663545</metadatatoken><br> <assembly>MailClient.Accounts</assembly><br> <type>MailClient.Storage.Views.ItemCollectionView
2
folder_RefreshItems
mscorlib
System.Object
sender
MailClient.Storage
e
42
d9
100665497
MailClient.Accounts
1
UpdateAndNotify
changeEvent
34a
111a
null
MailClient.exe
MailClient.exe
MailClient.exe
7.0.27943.0
eM Client
eM Client
7.0.27943.0
False
False
False
False
False
Language Neutral
ntdll.dll
ntdll.dll
ntdll.dll.mui
NT Layer DLL
10.0.14393.206
False
False
False
False
False
MSCOREE.DLL
mscoree.dll
mscoree.dll
10.0.14393.0
False
False
False
False
False
KERNEL32.dll
kernel32
kernel32
10.0.14393.206
False
False
False
False
False
KERNELBASE.dll
Kernelbase.dll
Kernelbase.dll.mui
10.0.14393.206
False
False
False
False
False
ADVAPI32.dll
advapi32.dll
advapi32.dll.mui
10.0.14393.0
False
False
False
False
False
msvcrt.dll
msvcrt.dll
msvcrt.dll
Windows NT CRT DLL
7.0.14393.0
False
False
False
False
False
sechost.dll
sechost.dll
sechost.dll.mui
10.0.14393.0
False
False
False
False
False
RPCRT4.dll
rpcrt4.dll
rpcrt4.dll.mui
10.0.14393.0
False
False
False
False
False
SspiCli.dll
security.dll
security.dll
10.0.14393.187
False
False
False
False
False
CRYPTBASE.dll
cryptbase.dll
cryptbase.dll
10.0.14393.0
False
False
False
False
False
10.0.14393.0
False
False
False
False
False
mscoreei.dll
mscoreei.dll
mscoreei.dll
4.6.1586.0
False
False
False
True
False
SHLWAPI.dll
SHLWAPI
SHLWAPI.DLL.MUI
10.0.14393.0
False
False
False
False
False
combase.dll
COMBASE.DLL
COMBASE.DLL.MUI
10.0.14393.0
False
False
False
False
False
ucrtbase.dll
ucrtbase.dll
ucrtbase.dll
10.0.14393.0
False
False
False
False
False
GDI32.dll
gdi32
gdi32
GDI Client DLL
10.0.14393.206
False
False
False
False
False
gdi32full.dll
gdi32
gdi32
GDI Client DLL
10.0.14393.447
False
False
False
False
False
USER32.dll
user32
user32
10.0.14393.0
False
False
False
False
False
win32u.dll
Win32u
Win32u.DLL
Win32u
10.0.14393.51
False
False
False
False
False
IMM32.DLL
imm32
imm32
10.0.14393.0
False
False
False
False
False
kernel.appcore.dll
kernel.appcore.dll
kernel.appcore.dll
AppModel API Host
10.0.14393.0
False
False
False
False
False
VERSION.dll
version
VERSION.DLL
10.0.14393.0
False
False
False
False
False
clr.dll
clr.dll
clr.dll
4.6.1586.0
False
False
False
True
False
12.00.52512.0
False
False
False
False
False
mscorlib.ni.dll
mscorlib.dll
mscorlib.dll
4.6.1586.0
False
False
False
True
False
ole32.dll
OLE32.DLL
OLE32.DLL.MUI
10.0.14393.0
False
False
False
False
False
uxtheme.dll
UxTheme.dll
UxTheme.dll.mui
10.0.14393.0
False
False
False
False
False
CRYPTSP.dll
cryptsp.dll
cryptsp.dll
10.0.14393.0
False
False
False
False
False
rsaenh.dll
rsaenh.dll
rsaenh.dll.mui
10.0.14393.0
False
False
False
False
False
bcrypt.dll
bcrypt.dll
bcrypt.dll.mui
10.0.14393.0
False
False
False
False
False
System.ni.dll
System.dll
System.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
MailClient.Mail.dll
MailClient.Mail.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
HtmlEditorControl
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.ni.exe
MailClient.exe
MailClient.exe
7.0.27943.0
eM Client
eM Client
7.0.27943.0
False
False
False
False
False
Language Neutral
LinqBridge.ni.dll
LinqBridge.dll
LinqBridge.dll
1.3.13216.2214
LINQBridge
LINQBridge
1.3.13216.2214
False
False
False
False
False
Language Neutral
7.0.27943.0
MailClient.Accounts
MailClient.Accounts
7.0.27943.0
False
False
False
False
False
Language Neutral
System.Drawing.dll
System.Drawing.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
.NET Framework
4.6.1586.0
False
False
False
True
False
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
1.0.0.0
1.0.0.0
False
False
False
False
False
Language Neutral
jabber-net.ni.dll
jabber-net.dll
jabber-net.dll
7.0.0.3
Jabber-Net library
jabber-net
7.0.0.3
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
Xilium.CefGlue.dll
Xilium.CefGlue.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
1.0.0.3
1.0.0.3
False
False
False
False
False
Language Neutral
WinApi.ni.dll
WinApi.dll
WinApi.dll
1.1.27943.0
WinApi
WinApi
1.1.27943.0
False
False
False
False
False
Language Neutral
System.Core.ni.dll
System.Core.dll
System.Core.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
System.Data.ni.dll
system.data.dll
system.data.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
System.Data.dll
system.data.dll
system.data.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
WS2_32.dll
ws2_32.dll
ws2_32.dll.mui
10.0.14393.0
False
False
False
False
False
CRYPT32.dll
CRYPT32.DLL
CRYPT32.DLL.MUI
Crypto API32
10.0.14393.0
False
False
False
False
False
MSASN1.dll
msasn1.dll
msasn1.dll
ASN.1 Runtime APIs
10.0.14393.0
False
False
False
False
False
libcef.DLL
libcef
libcef.dll
False
False
False
False
False
PSAPI.DLL
PSAPI
PSAPI
10.0.14393.0
False
False
False
False
False
USP10.dll
USP10.DLL
USP10.DLL
10.0.14393.0
False
False
False
False
False
COMDLG32.dll
comdlg32
comdlg32.dll.mui
Common Dialogs DLL
10.0.14393.0
False
False
False
False
False
WINSPOOL.DRV
winspool.drv
winspool.drv.mui
10.0.14393.0
False
False
False
False
False
shcore.dll
SHCORE
SHCORE.dll.mui
SHCORE
10.0.14393.0
False
False
False
False
False
SHELL32.dll
SHELL32
SHELL32.DLL.MUI
10.0.14393.0
False
False
False
False
False
cfgmgr32.dll
cfgmgr32.dll
CFGMGR32.DLL
10.0.14393.0
False
False
False
False
False
COMCTL32.dll
comctl32
comctl32.DLL.MUI
10.0.14393.447
False
False
False
False
False
windows.storage.dll
Windows.Storage
10.0.14393.0
False
False
False
False
False
powrprof.dll
POWRPROF
POWRPROF.DLL.MUI
10.0.14393.0
False
False
False
False
False
profapi.dll
PROFAPI.DLL
PROFAPI.DLL
10.0.14393.0
False
False
False
False
False
OLEAUT32.dll
OLEAUT32.DLL
OLEAUT32.DLL
OLEAUT32.DLL
10.0.14393.447
False
False
False
False
False
msvcp_win.dll
msvcp_win.dll
msvcp_win.dll
10.0.14393.0
False
False
False
False
False
WINHTTP.dll
winhttp.dll
winhttp.dll.mui
10.0.14393.0
False
False
False
False
False
USERENV.dll
userenv
userenv.dll.mui
Userenv
10.0.14393.0
False
False
False
False
False
urlmon.dll
UrlMon.dll
UrlMon.dll.mui
Internet Explorer
11.00.14393.0
False
False
False
False
False
dhcpcsvc.DLL
dhcpcsvc.dll
dhcpcsvc.dll.mui
DHCP Client Service
10.0.14393.0
False
False
False
False
False
NSI.dll
nsi.dll
nsi.dll
10.0.14393.0
False
False
False
False
False
WTSAPI32.dll
wtsapi32.dll
wtsapi32.dll
10.0.14393.0
False
False
False
False
False
OLEACC.dll
OLEACC
OLEACC.DLL
10.0.14393.206
False
False
False
False
False
Language Neutral
WINMM.dll
winmm.dll
WINMM.DLL.MUI
MCI API DLL
10.0.14393.0
False
False
False
False
False
Secur32.dll
secur32.dll
secur32.dll
10.0.14393.0
False
False
False
False
False
IPHLPAPI.DLL
iphlpapi.dll
iphlpapi.dll.mui
IP Helper API
10.0.14393.0
False
False
False
False
False
iertutil.dll
IeRtUtil.dll
IeRtUtil.dll.mui
Internet Explorer
11.00.14393.0
False
False
False
False
False
WINMMBASE.dll
winmmbase.dll
WINMMbase.DLL.MUI
10.0.14393.0
False
False
False
False
False
4.6.1586.0
False
False
False
True
False
System.Xml.ni.dll
System.Xml.dll
System.Xml.dll
.NET Framework
4.6.1586.0
False
False
False
True
False
comctl32.dll
COMCTL32
COMCTL32.DLL.MUI
10.0.14393.447
False
False
False
False
False
dwmapi.dll
dwmapi.dll
dwmapi.dll.mui
10.0.14393.0
False
False
False
False
False
MSCTF.dll
MSCTF
MSCTF.DLL.MUI
MSCTF Server DLL
10.0.14393.0
False
False
False
False
False
gdiplus.dll
gdiplus
gdiplus
Microsoft GDI+
10.0.14393.321
False
False
False
False
False
4.6.1586.0
False
False
False
True
False
mswsock.dll
mswsock.dll
mswsock.dll.mui
10.0.14393.0
False
False
False
False
False
diasymreader.dll
diasymreader.dll
diasymreader.dll
Dia based SymReader
14.6.1586.0
False
False
False
False
False
PROPSYS.dll
propsys.dll
propsys.dll.mui
Windows® Search
7.0.14393.0
False
False
False
False
False
clbcatq.dll
CLBCATQ.DLL
CLBCATQ.DLL
10.0.14393.0
False
False
False
False
False
edputil.dll
EDPUTIL.DLL
EDPUTIL.DLL.MUI
EDP util
10.0.14393.0
False
False
False
False
False
1.0.84.2
System.Data.SQLite
1.0.84.2
False
False
False
False
False
Language Neutral
sqlite3.dll
False
False
False
False
False
1.0.0.0
1.0.0.0
False
False
False
False
False
.NET Framework
4.6.1586.0
False
False
False
True
False
.NET Framework
4.6.1586.0
False
False
False
True
False
4.6.1586.0
False
False
False
True
False
4.6.1586.0
False
False
False
True
False
4.6.1586.0
False
False
False
True
False
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
clrjit.dll
clrjit.dll
clrjit.dll
4.6.1586.0
False
False
False
True
False
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
MailClient.Commands
MailClient.Commands
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
MailClient.Objects
MailClient.Objects
7.0.27943.0
False
False
False
False
False
Language Neutral
1.0.0.4
SystemCoreTimeZone
SystemCoreTimeZone
1.0.0.4
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
MailClient.IM.dll
MailClient.IM.dll
7.0.27943.0
MailClient.IM
MailClient.IM
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
NLAapi.dll
nlaapi.dll
nlaapi.dll
10.0.14393.0
False
False
False
False
False
audioses.dll
AudioSession
AudioSes.Dll.MUI
Audio Session
10.0.14393.0
False
False
False
False
False
MMDevAPI.DLL
MMDeviceAPI
MMDevAPI.Dll.MUI
MMDevice API
10.0.14393.0
False
False
False
False
False
wintypes.dll
WinTypes.dll.mui
10.0.14393.0
False
False
False
False
False
DEVOBJ.dll
devinfoset.dll
devinfoset.DLL
10.0.14393.0
False
False
False
False
False
dhcpcsvc6.DLL
dhcpcsvc6.dll
dhcpcsvc6.dll.mui
DHCPv6 Client
10.0.14393.0
False
False
False
False
False
SETUPAPI.dll
SETUPAPI.DLL
SETUPAPI.DLL.MUI
Windows Setup API
10.0.14393.0
False
False
False
False
False
WINTRUST.dll
WINTRUST.DLL
WINTRUST.DLL
10.0.14393.351
False
False
False
False
False
DWrite.dll
DWrite
DWrite
10.0.14393.0
False
False
False
False
False
UNKNOWN_FILE
UNKNOWN_FILE
.NET Framework
4.6.1586.0
False
False
False
True
False
WindowsCodecs.dll
WindowsCodecs
WindowsCodecs
10.0.14393.206
False
False
False
False
False
0.0.0.0
0.0.0.0
False
False
False
False
False
Language Neutral
7.0.27943.0
MailClient.Contact
MailClient.Contact
7.0.27943.0
False
False
False
False
False
Language Neutral
dataexchange.dll
DataExchange
DataExchange.dll
Data exchange
10.0.14393.206
False
False
False
False
False
dcomp.dll
dcomp.dll
dcomp.dll.mui
10.0.14393.0
False
False
False
False
False
d3d11.dll
D3D11.dll
D3D11.dll
Direct3D 11 Runtime
10.0.14393.351
False
False
False
False
False
dxgi.dll
dxgi.dll
dxgi.dll
10.0.14393.0
False
False
False
False
False
twinapi.appcore.dll
twinapi.appcore
twinapi.appcore
10.0.14393.0
False
False
False
False
False
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
napinsp.dll
napinsp.dll
napinsp.dll.mui
10.0.14393.0
False
False
False
False
False
pnrpnsp.dll
pnrpnsp.dll
pnrpnsp.dll.mui
10.0.14393.0
False
False
False
False
False
DNSAPI.dll
dnsapi
dnsapi
DNS Client API DLL
10.0.14393.0
False
False
False
False
False
winrnr.dll
winrnr
winrnr
10.0.14393.0
False
False
False
False
False
14.6.1586.0
False
False
False
True
False
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
WINSTA.dll
winsta
winsta.dll
Winstation Library
10.0.14393.0
False
False
False
False
False
10.0.14393.0
False
False
False
False
False
atlthunk.dll
atlthunk.dll
atlthunk.dll
atlthunk.dll
10.0.14393.0
False
False
False
False
False
1.0.1.0
WindowsAPICodePack
WindowsAPICodePack
1.0.1.0
False
False
False
False
False
Language Neutral
WINNSI.DLL
winnsi.dll
winnsi.dll
10.0.14393.0
False
False
False
False
False
LINKINFO.dll
LINKINFO
LINKINFO.DLL
10.0.14393.0
False
False
False
False
False
Bcp47Langs.dll
BCP47Lang.dll
BCP47Lang.dll
10.0.14393.0
False
False
False
False
False
ntshrui.dll
ntshrui
ntshrui.dll.mui
10.0.14393.0
False
False
False
False
False
srvcli.dll
SRVCLI.DLL
SRVCLI.DLL
10.0.14393.0
False
False
False
False
False
cscapi.dll
cscapi.dll
cscapi.dll
10.0.14393.0
False
False
False
False
False
ntmarta.dll
ntmarta.dll
ntmarta.dll.mui
10.0.14393.0
False
False
False
False
False
MailClient.Sasl.dll
MailClient.Sasl.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
rasadhlp.dll
rasadhlp.dll
rasadhlp.dll
10.0.14393.0
False
False
False
False
False
fwpuclnt.dll
fwpuclnt.dll
fwpuclnt.dll.mui
10.0.14393.0
False
False
False
False
False
schannel.dll
schannel.dll
schannel.dll.mui
10.0.14393.0
False
False
False
False
False
mskeyprotect.dll
mskeyprotect.dll
10.0.14393.0
False
False
False
False
False
ncrypt.dll
ncrypt.dll
ncrypt.dll.mui
10.0.14393.0
False
False
False
False
False
NTASN1.dll
ntasn1.dll
ntasn1.dll.mui
Microsoft ASN.1 API
10.0.14393.0
False
False
False
False
False
ncryptsslp.dll
ncryptsslp.dll
ncryptsslp.dll
10.0.14393.0
False
False
False
False
False
mscms.dll
MSCMS.DLL
MSCMS.DLL.MUI
10.0.14393.0
False
False
False
False
False
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
0.2.1.1
NTextCat
0.2.1.1
False
False
False
False
False
Language Neutral
0.2.1.1
NTextCat
0.2.1.1
False
False
False
False
False
Language Neutral
SgmlReader.ni.dll
SgmlReader.dll
SgmlReader.dll
7.0.27943.0
SgmlReader
SgmlReader
7.0.27943.0
False
False
False
False
False
Language Neutral
thumbcache.dll
thumbcache.dll
thumbcache.dll.mui
10.0.14393.0
False
False
False
False
False
MrmCoreR.dll
MrmCore
MrmCore.dll.mui
10.0.14393.0
False
False
False
False
False
policymanager.dll
PolicyManager.dll
PolicyManager.dll
Policy Manager DLL
10.0.14393.0
False
False
False
False
False
msvcp110_win.dll
msvcp110_win.dll
msvcp110_win.dll
10.0.14393.0
False
False
False
False
False
explorerframe.dll
ExplorerFrame
ExplorerFrame
10.0.14393.0
False
False
False
False
False
ActXPrxy.dll
ActXPrxy.dll
ActXPrxy.dll
10.0.14393.0
False
False
False
False
False
wkscli.dll
WKSCLI.DLL
WKSCLI.DLL
10.0.14393.0
False
False
False
False
False
netutils.dll
NETUTILS.DLL
NETUTILS.DLL
10.0.14393.0
False
False
False
False
False
provsvc.dll
provsvc
provsvc.dll.mui
Windows HomeGroup
10.0.14393.0
False
False
False
False
False
ICONCODESERVICE.DLL
ICONCODESERVICE.DLL
10.0.14393.0
False
False
False
False
False
pcacli.dll
10.0.14393.0
False
False
False
False
False
MPR.dll
mpr.dll
mpr.dll.mui
10.0.14393.0
False
False
False
False
False
sfc_os.dll
sfc_os.dll
sfc_os.dll
10.0.14393.0
False
False
False
False
False
DEVRTL.dll
DEVRTL.dll
DEVRTL.DLL
10.0.14393.0
False
False
False
False
False
QuartzTypeLib
QuartzTypeLib.dll
1.0.0.0
1.0.0.0
False
False
False
False
False
quartz.dll
Quartz.dll
Quartz.dll.mui
DirectShow Runtime.
10.0.14393.0
False
False
False
False
False
devenum.dll
devenum.dll
devenum.dll.mui
Device enumeration.
10.0.14393.0
False
False
False
False
False
vsfilter.dll
VSFilter
VSFilter.dll
VSFilter
False
False
False
False
False
WININET.dll
wininet.dll
wininet.dll.mui
Internet Explorer
11.00.14393.447
False
False
False
False
False
clm4splt.ax
clm4splt.ax
1.0.2803
1.0.2803
False
False
False
False
False
LAVSplitter.ax
LAVSplitter.ax
LAVSplitter.ax
0.64.0.26-git
LAV Splitter
0.64.0.26-git
False
False
False
False
False
libbluray.dll
False
False
False
False
False
avformat-lav-56.dll
libavformat
avformat-lav-56.dll
56.26.101
FFmpeg
False
False
False
False
False
English (United States)
avutil-lav-54.dll
libavutil
avutil-lav-54.dll
54.20.100
FFmpeg
False
False
False
False
False
avcodec-lav-56.dll
libavcodec
avcodec-lav-56.dll
56.29.100
FFmpeg
False
False
False
False
False
libavresample
2.1.0
FFmpeg
False
False
False
False
False
.NET Framework
4.6.1586.0
False
False
False
True
False
wdmaud.drv
wdmaud.drv
wdmaud.drv.mui
10.0.14393.0 (rs1_release.160715-1616)
Microsoft® Windows® Operating System
10.0.14393.0
False
False
False
False
False
ksuser.dll
ksuser.dll
ksuser.dll
User CSA Library
10.0.14393.0
False
False
False
False
False
Language Neutral
AVRT.dll
avrt.dll
avrt.dll
10.0.14393.0
False
False
False
False
False
msacm32.drv
msacm32.acm.mui
10.0.14393.0
False
False
False
False
False
MSACM32.dll
msfltr32.acm.mui
10.0.14393.0
False
False
False
False
False
midimap.dll
midimap
midimap.dll.mui
10.0.14393.0
False
False
False
False
False
DSOUND.DLL
DirectSound
dsound.dll.mui
DirectSound
10.0.14393.0
False
False
False
False
False
apphelp.dll
Apphelp
Apphelp
10.0.14393.0
False
False
False
False
False
10.0.14393.0
False
False
False
False
False
NHunspell.ni.dll
NHunspell.dll
NHunspell.dll
7.0.27943.0
7.0.27943.0
False
False
False
False
False
Language Neutral
ExCSS.ni.dll
ExCSS.dll
ExCSS.dll
1.0.0.0
ExCSS
ExCSS
1.0.0.0
False
False
False
False
False
Language Neutral
RtfToHtml.ni.dll
RtfToHtml.dll
RtfToHtml.dll
1.0.0.1
RtfToHtml
RtfToHtml
1.0.0.1
False
False
False
False
False
Language Neutral
Hunspellx86.dll
Hunspell
1,2,5554,16953
1.2.5554.16953
False
False
False
False
False
German (Germany)
twinui.dll
TWINUI
TWINUI.dll.mui
TWINUI
10.0.14393.0
False
False
False
False
False
twinui.appcore.dll
TWINUI.APPCORE
TWINUI.APPCORE
10.0.14393.0
False
False
False
False
False
execmodelproxy.dll
ExecModelProxy
ExecModelProxy.dll
ExecModelProxy
10.0.14393.0
False
False
False
False
False
Windows.UI.dll
Windows.UI.dll.MUI
10.0.14393.0
False
False
False
False
False
</.ctor></.ctor>
