Hi all!
Are there any hotkeys for favourites ? Or is it possible to set up navigation through favourites with hot keys ?
Thanks in advance !
Hi all!
Thanks in advance !
eM Client shortcuts are all via the “Menu / Settings / General / Shortcuts” (PC) “eM Client / Preferences / General / Shortcuts” (Mac).
You can select the shortcut you wish to modify and change it according to your preference.
Other than that, it would be a feature request.
So currently it’s impossible
Created feature request
thanks
