I am running emclient 7.x with a nextcloud version 20 backend that I just setup on debian 10. No problems on nextcloud and runs fine. However, I am getting a sync error via emclient on windows 10:
8:39:36 AM user [CalDAV / CardDAV] Synchronizing subfolders: For folder user/trashbin/objects/
8:39:37 AM user [CalDAV / CardDAV] MailClient.Storage.Application.OperationException: Subfolder synchronization for folder "objects" failed due to the following error: Not Implemented
I am getting a pop up window with this error everytime emclient syncs with the nextcloud server. The only thing I can figure out is that /trashbin/Objects might have something to do with a trashbin for calendar appointments - so you can restore them when deleted. Some how emclient does not support this and thats why the error?? Either that or something is missing in nextcloud like an add on app or a misconfiguration??
Darn it. Nevermind. I have solved the issue. I upgraded from 7 to 8 and I no longer get these popups.
I swear, Everytime I spend hours trying to figure out a problem and then finally decide to post about - I find the problem soon after I post about it.
Well, At least this is here for anyone that scratching their head like I was.
Hi Gary,
I had it on a persons computer with version 8. I checked everything and then downgraded to 7. 7 seemed to work fine. I do not have one with that issue now but I did read about some others having it and just wondered if anything became of it. If it happens again I will post about it.
