eM Client (6.0.22328.0)Windows: Microsoft Windows NT 6.1.7601 Service Pack 1, Framework: 4.0.30319.17929
System.Data.SQLite.SQLiteException (0x80004005): attempt to write a readonly database
at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
at MailClient.Storage.Data.SQLite.DbRepository1..ctor(Compactor compactor, String indexTable, String[] readWriteDatabaseNames, String[] readOnlyDatabaseNames) at MailClient.Storage.Data.DbCategoriesItemRepository
1…ctor(Compactor compactor, String indexTable, String[] readWriteDatabaseNames, String[] readOnlyDatabaseNames)
at MailClient.Storage.Data.SQLite.DbMailRepository…ctor(Compactor compactor)
at MailClient.Storage.Data.RepositoryFactory.get_MailRepository()
at MailClient.Storage.Application.Folder.CreateMailItemsCollection()
at MailClient.Storage.Application.Folder.get_MailItems()
at MailClient.UI.Controls.controlMailFolders.AttachUnreadCallbacks()
at MailClient.UI.Controls.controlMailUserFolders.AttachCallbacks()
at MailClient.UI.Controls.controlFolders.LoadNodes()
at MailClient.UI.Controls.controlFolders.OnLoad(EventArgs e)
at MailClient.UI.Controls.controlMailFolders.OnLoad(EventArgs e)
at System.Windows.Forms.UserControl.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.OnVisibleChanged(EventArgs e)
at System.Windows.Forms.ScrollableControl.OnVisibleChanged(EventArgs e)
at System.Windows.Forms.Control.OnParentVisibleChanged(EventArgs e)
at System.Windows.Forms.Form.OnVisibleChanged(EventArgs e)
at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at MailClient.Program.b__4()
at MailClient.ExceptionUtils.ExceptionUtils.Filter(BodyDelegate body, FilterDelegate filter, Action1 handler)<br><br><br><report xmlns="<a href=" http:>" rel="nofollow" target="_blank">http://emclient.com/ns/report">;<br> <product><br> <name>eM Client</name><br> <version>6.0.22328.0</version><br> </product><br> <silent>false</silent><br> <environment><br> <osversion>Microsoft Windows NT 6.1.7601 Service Pack 1</osversion><br> <frameworkversion>4.0.30319.17929</frameworkversion><br> </environment><br> <exception><br> <type>System.Data.SQLite.SQLiteException</type><br> <message>attempt to write a readonly database<br>attempt to write a readonly database</message><br> <source>System.Data.SQLite</source><br> <stack><br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663598</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLite3</type><br> <name>Reset</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteStatement</type><br> <name>stmt</name><br> </parameter><br> </parameters><br> </method><br> <offset>83</offset><br> <nativeoffset>29992</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663597</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLite3</type><br> <name>Step</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteStatement</type><br> <name>stmt</name><br> </parameter><br> </parameters><br> </method><br> <offset>3c</offset><br> <nativeoffset>bb</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663982</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteDataReader</type><br> <name>NextResult</name><br> <parameters></parameters><br> </method><br> <offset>12f</offset><br> <nativeoffset>150</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663943</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteDataReader</type><br> <name>.ctor</name><br> <parameters><br> <parameter><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>cmd</name><br> </parameter><br> <parameter><br> <assembly>System.Data</assembly><br> <type>System.Data.CommandBehavior</type><br> <name>behave</name><br> </parameter><br> </parameters><br> </method><br> <offset>5d</offset><br> <nativeoffset>71</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663757</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>ExecuteReader</name><br> <parameters><br> <parameter><br> <assembly>System.Data</assembly><br> <type>System.Data.CommandBehavior</type><br> <name>behavior</name><br> </parameter><br> </parameters><br> </method><br> <offset>c</offset><br> <nativeoffset>26</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Data.SQLite.dll</modulename><br> <metadatatoken>100663760</metadatatoken><br> <assembly>System.Data.SQLite</assembly><br> <type>System.Data.SQLite.SQLiteCommand</type><br> <name>ExecuteNonQuery</name><br> <parameters></parameters><br> </method><br> <offset>6</offset><br> <nativeoffset>21</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100670193</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Data.SQLite.DbRepository
1
.ctor
MailClient
MailClient.Storage.Data.Compactor
compactor
mscorlib
System.String
indexTable
mscorlib
System.String[]
mscorlib
System.String[]
a2
198
MailClient.exe
100670240
MailClient
MailClient.Storage.Data.DbCategoriesItemRepository1</type><br> <name>.ctor</name><br> <parameters><br> <parameter><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Data.Compactor</type><br> <name>compactor</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.String</type><br> <name>indexTable</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.String[]</type><br> <name>readWriteDatabaseNames</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.String[]</type><br> <name>readOnlyDatabaseNames</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>48</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100685620</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Data.SQLite.DbMailRepository</type><br> <name>.ctor</name><br> <parameters><br> <parameter><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Data.Compactor</type><br> <name>compactor</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>9f</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100686149</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Data.RepositoryFactory</type><br> <name>get_MailRepository</name><br> <parameters></parameters><br> </method><br> <offset>1a</offset><br> <nativeoffset>6f</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100677088</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Application.Folder</type><br> <name>CreateMailItemsCollection</name><br> <parameters></parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>17</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100677087</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Storage.Application.Folder</type><br> <name>get_MailItems</name><br> <parameters></parameters><br> </method><br> <offset>1a</offset><br> <nativeoffset>2a</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100678680</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.controlMailFolders</type><br> <name>AttachUnreadCallbacks</name><br> <parameters></parameters><br> </method><br> <offset>12</offset><br> <nativeoffset>52</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100678752</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.controlMailUserFolders</type><br> <name>AttachCallbacks</name><br> <parameters></parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>e</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100678515</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.controlFolders</type><br> <name>LoadNodes</name><br> <parameters></parameters><br> </method><br> <offset>98</offset><br> <nativeoffset>18d</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100678512</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.controlFolders</type><br> <name>OnLoad</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>53</offset><br> <nativeoffset>99</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100678673</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.controlMailFolders</type><br> <name>OnLoad</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>d</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100682727</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.UserControl</type><br> <name>OnCreateControl</name><br> <parameters></parameters><br> </method><br> <offset>6</offset><br> <nativeoffset>29</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665625</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>CreateControl</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>fIgnoreVisible</name><br> </parameter><br> </parameters><br> </method><br> <offset>bf</offset><br> <nativeoffset>193</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665625</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>CreateControl</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>fIgnoreVisible</name><br> </parameter><br> </parameters><br> </method><br> <offset>92</offset><br> <nativeoffset>150</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665625</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>CreateControl</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>fIgnoreVisible</name><br> </parameter><br> </parameters><br> </method><br> <offset>92</offset><br> <nativeoffset>150</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665625</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>CreateControl</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>fIgnoreVisible</name><br> </parameter><br> </parameters><br> </method><br> <offset>92</offset><br> <nativeoffset>150</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665625</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>CreateControl</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>fIgnoreVisible</name><br> </parameter><br> </parameters><br> </method><br> <offset>92</offset><br> <nativeoffset>150</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665625</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>CreateControl</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>fIgnoreVisible</name><br> </parameter><br> </parameters><br> </method><br> <offset>92</offset><br> <nativeoffset>150</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665244</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>CreateControl</name><br> <parameters></parameters><br> </method><br> <offset>7</offset><br> <nativeoffset>27</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665324</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>OnVisibleChanged</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>34</offset><br> <nativeoffset>168</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665964</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ScrollableControl</type><br> <name>OnVisibleChanged</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>14</offset><br> <nativeoffset>54</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665318</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>OnParentVisibleChanged</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>9</offset><br> <nativeoffset>13</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665324</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>OnVisibleChanged</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>8c</offset><br> <nativeoffset>11f</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665964</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ScrollableControl</type><br> <name>OnVisibleChanged</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>14</offset><br> <nativeoffset>54</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100674905</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Form</type><br> <name>OnVisibleChanged</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>16</offset><br> <nativeoffset>48</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665432</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>SetVisibleCore</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>value</name><br> </parameter><br> </parameters><br> </method><br> <offset>ec</offset><br> <nativeoffset>2a8</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100674828</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Form</type><br> <name>SetVisibleCore</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>value</name><br> </parameter><br> </parameters><br> </method><br> <offset>8c</offset><br> <nativeoffset>7e</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665131</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>set_Visible</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>value</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>13</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100688529</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Application+ThreadContext</type><br> <name>RunMessageLoopInner</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>reason</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ApplicationContext</type><br> <name>context</name><br> </parameter><br> </parameters><br> </method><br> <offset>92</offset><br> <nativeoffset>d3</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100688528</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Application+ThreadContext</type><br> <name>RunMessageLoop</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>reason</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ApplicationContext</type><br> <name>context</name><br> </parameter><br> </parameters><br> </method><br> <offset>13</offset><br> <nativeoffset>49</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100664859</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Application</type><br> <name>Run</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ApplicationContext</type><br> <name>context</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>17</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100675709</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Program</type><br> <name><Main>b__4</name><br> <parameters></parameters><br> </method><br> <offset>17</offset><br> <nativeoffset>42</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.ExceptionUtils.dll</modulename><br> <metadatatoken>100663314</metadatatoken><br> <assembly>MailClient.ExceptionUtils</assembly><br> <type>MailClient.ExceptionUtils.ExceptionUtils</type><br> <name>Filter</name><br> <parameters><br> <parameter><br> <assembly>MailClient.ExceptionUtils</assembly><br> <type>MailClient.ExceptionUtils.ExceptionUtils+BodyDelegate</type><br> <name>body</name><br> </parameter><br> <parameter><br> <assembly>MailClient.ExceptionUtils</assembly><br> <type>MailClient.ExceptionUtils.ExceptionUtils+FilterDelegate</type><br> <name>filter</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Action
1[[System.Exception, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]
handler
0
22
183
MailClient.exe
C:\Program Files (x86)\eM Client\MailClient.exe
MailClient.exe
MailClient.exe
6.0.22328.0
eM Client
eM Client
6.0.22328.0
False
False
False
False
False
Language Neutral
ntdll.dll
C:\Windows\SysWOW64\ntdll.dll
ntdll.dll
ntdll.dll.mui
6.1.7600.16385 (win7_rtm.090713-1255)
NT Layer DLL
Microsoft® Windows® Operating System
6.1.7600.16385
False
False
False
False
False
English (United States)
MSCOREE.DLL
C:\Windows\SYSTEM32\MSCOREE.DLL
mscoree.dll
mscoree.dll
4.0.40305.0 (Main.040305-0000)
Microsoft .NET Runtime Execution Engine
Microsoft® .NET Framework
4.0.40305.0
False
False
False
True
False
KERNEL32.dll
C:\Windows\syswow64\KERNEL32.dll
kernel32
kernel32
6.1.7601.17965 (win7sp1_gdr.121004-0333)
Windows NT BASE API Client DLL
6.1.7601.17965
False
False
False
False
False
KERNELBASE.dll
C:\Windows\syswow64\KERNELBASE.dll
Kernelbase
Kernelbase
6.1.7601.17965
False
False
False
False
False
ADVAPI32.dll
C:\Windows\syswow64\ADVAPI32.dll
advapi32.dll
advapi32.dll.mui
Advanced Windows 32 Base API
6.1.7600.16385
False
False
False
False
False
msvcrt.dll
C:\Windows\syswow64\msvcrt.dll
msvcrt.dll
msvcrt.dll
7.0.7601.17744 (win7sp1_gdr.111215-1535)
Windows NT CRT DLL
7.0.7601.17744
False
False
False
False
False
sechost.dll
C:\Windows\SysWOW64\sechost.dll
sechost.dll
sechost.dll.mui
Host for SCM/SDDL/LSA Lookup APIs
6.1.7600.16385
False
False
False
False
False
RPCRT4.dll
Hello Josh, if I understand this correctly you’re able to access your database data after a computer restart, but if you close and reopen the application, this error is thrown?
Can you please install this update and check if the issue persists?
6.0.22336.0
Paul
