Error connecting to IMAP Gandi servers
My email works fine , I can send and receive but I keep getting this message all the passwords are correct and it seems to work fine
![]( “Image null”) ![]( “Image: null”)
Hi Paul, one of the errors seems to be related to an authentication issue? Are you completely sure all your accounts synchronize without any issues?
If you’re using a google account with two step verification option, please make sure to generate an app specific password for use with eM Client or make sure you have this setting enabled to use eM client with your standard web access password.
https://www.google.com/settings/security/lesssecureapps
Paul
