Error al Comprobar base de datos de emclient
Hola buenos dias se solicita de su apoyo para la solucion al error al comprobar la base de datos de emclient, al iniciar emclient se presenta este error. agradezco su pronto apoyo ya que es el usuario de recursos humanos y actualmente se encuentra sin correo. Gracias
System.ApplicationException: SQL logic error or missing database
no such table: mail_data.LocalMailContents
Line: 9
DELETE FROM mail_index.MailItems WHERE NOT EXISTS(SELECT id FROM mail_data.LocalMailContents WHERE id=mail_index.MailItems.id LIMIT 1);
en MailClient.Storage.Data.DbRepository1.ImportFromResource(IDbConnection connection, Stream myStream, CancellationToken token) en MailClient.Storage.Data.DbRepository1.ImportFromManifestResource(String resourceName, CancellationToken token)
en MailClient.Storage.Data.DbRepository1.Repair(RepairMode mode, CancellationToken token) en MailClient.Accounts.ItemRepositories.Repair(RepairMode mode, CancellationToken token) en DbRepair.ConsistencyChecker.CheckConsistencyForAccount(String accountDirectory, RepairMode mode, CancellationToken token) en DbRepair.ConsistencyChecker.<>c__DisplayClass2_0.<Check>b__0(String p) en DbRepair.PerAccountExecutor.Execute(String dataStoreLocation, Func2 action)
en DbRepair.ConsistencyChecker.Check(RepairMode mode, CancellationToken token)
en DbRepair.CheckingProcess.Check(CancellationToken token)
Data:
ResourceName: MailClient.Storage.Mail.Data.DbMailRepository.consistency.sql
DatastoreLocation: C:\Users\Administrador\AppData\Roaming\eM Client\
I did not see any solutions on this forum for corrupted databases except to delete them and start again.
To do that you should delete or rename the C:\Users\Administrador\AppData\Roaming\eM Client\ directory then restart eM Client. You may have to enable hidden items in Windows Explorer to get there.
Once eM Client has restarted, you can restore your most recent backup, or setup your accounts again.
Or, if you have a Pro License, you can open a support ticket with eM Client. Maybe they will have some other suggestion.
