Endelss need to restart eM CLient
  • Em Client: 10.4.5606
  • OS: Windows 11 Pro for Workstations, Build 26200
I am currently using Outlook and am testing out eM Client for a possible replacement. I test it on two different computers but notice the same thing on both computers.
It is hard to reproduce, but i have seen when i have created a new Rule, that when i run it nothing happens. The Rule were set to move mails from Inbox (IMAP or POP3) to a local Inbox. If i closed eM Client and restarted it and run the Rule again it worked.
Or, one hour later it seems like another Rule did nothing so i closed eM Client and restarted it and now, without having to do anything again, the mails were already moved to the correct place.
Just now i wanted to copy 50 mails from a local folder to my IMAP folder. It seemed to work but only about 25 showed up in the IMAP folder. Again, close and restart was all i had to do to make all 50 show up as expected in the IMAP folder. Before i closed/restarted i logged in to my ISP and could confirm that all 50 mails already was on the server. A manual Refress in eM Client did nothing. A manual close/restart did.
Since i am new to eM CLient i wonder if this is the way the app works, iow that lots of close/restarts is needed to make it “wake up” and do what it is supposed to do?
I have never experienced this in Outlook, hence the question. :slight_smile:
Definitely not a designed behavior :slight_smile:
Rules are run automatically on new incoming messages in Inbox when “enabled” (they have a checkmark in the Menu>Rules section). You can also run/apply rules manually from the Rules window or via right-click on a folder > Apply rule (you can then select which rules to apply to which folder/s).
Getting new messages should be done within the sync interval, which you can customize in menu>Settings>General>General, under Synchronization.
POP accounts are checked and downloaded in that interval; IMAP accounts also use IDLE which keeps a connection open with the mail server - so if the server indicates there is a new message, it is synchronized right away. Otherwise it asks about new messages within that same interval.
If this behavior does not correspond with your accounts, please let us know who is the proivider for these accounts and we might need to check the logs - you can reach out to [email protected] for further troubleshooting.
(As a tip in the meantime - turning the app into offline mode and back online should reset the connection the same way as turning off the app and running it again, but faster. Use Menu>File>Work offline toi switch to offline mode; you can turn back online the same way or click “Refresh” to get back online)
It seems to be a general issue and not just an issue with Rules. For example, i imported my Outlook calendar from the .pst file. When done the calendar was empty in eM CLient. Close+restart and boom, the calendar was there. The same for importing contacts.The same for importing mails.The mails imported but were no where to found until i closed+restarted. only 260 mails so not thousands.
That´s a one off thing since i will not import my calendar twice a week, but combined with mails that do move from folder A to folder B and that the UI shows that nothing at all happened until close+restart is not a good sign. So the mails did actually move but eM Client failed to update the UI.
The .pst file is 134 mb large, so it should have no issues compared really large ones. I saw the same when imported the calendar from an .ics file as well. I saw the same thing before i deleted old mails in Outlook when that .pst was about 940 mb.
Computer:
HP Z4 G5 Workstation
Intel Xeon 16-core w5-2465X (3.1 GHz)
RAM: 128 GB
GPU: Nvidia RTX PRO 4000 Blackwell
Storage: 4x 8TB Samsung 9100 PRO Gen 5 (NVME)
I have never heard of this happening with import the way you describe; the program definitely does not need to restart to show local data.
If you can still replicate the issue with import (be it calendars, contacts or local emails), we’d really appreciate a screen recording from the app so we can analyze the issue in detail, please do reach out to [email protected], thank you.
