Encryption - include these certificates with outgoing messages
If I DO NOT select the “include these certificates with outgoing messages” check box for security profile, will my public keys still be sent with a message that I digitally sign?
In other words, I only want my public keys to be sent with messages that I digitally sign and NOT with every messages I send (signed or otherwise). What would be the correct selection to setup my profile?
Thanks.
Hi, to automatically sign all your messages, go to Tools > Settings > Mail > Certificates, setup a security profile and assign it to your account.
If you compose a new email, signed icon will be active automatically, you can also select to encrypt those mails.
Hope this helps,
Actually my question was… if an e-mail is NOT signed will the certificate be sent if the “include these certificates with outgoing messages” option is selected. In other words if I set my profile up as shown in the attached image will my certificate always be sent even if I DON’T sign the message. Thanks.
Ok, sorry for the misunderstanding, no the certificate will not be sent with the message if it’s not signed.
I tried this, but even if “Digitally sign messages (by default)” is checked, I still have to sign every mail individually. It seems not to do anything for me…
Hi Robert, did you create the security profile and assigned it to your account?
Yes I did. It works fine, if I check the button manually, I just cannot get it to be the default setting
What version of eM Client are you currently using?
6.0.20617.0
Can you please send me an email to [email protected]?
