I would emty trash with ione click
Could this be possible?
per costumize please …
How about right click on TRASH folder than left click on “empty trash”? 2 clicks.
sorry, em client 7
on emc 6 is that correct
but not on 7
I will not be moving to 7 for some time. Way too many complaints and 6 meets my needs perfectly, so “if it aint broke…”.
Maybe when 8 comes out, I’ll move to 7. :-)
Hello Sascha,
right-clicking on Trash and choosing Empty trash works in version 7 as well.
What accound does this issue happen on?
no empty trash
empty trash on a single account - okay
but not on smart folders
Hello Sascha,
I see, you did not mention you meant the Trash in Smart folders
We do have this marked as a Feature request though and it will be implemented in future upgrades.
sorry and thx 4 support
Sascha:
Here is an easy work-around that I am using to empty all the trash for all my email accounts in the eM Client 7 “Smart Folders / Trash” folder.
- Left-click “Trash” in the Smart Folders.
- Left-click “Menu / Message / Empty Trash” and that will empty all the trash in all your email accounts at one time.
Keep in mind that the procedure above will not empty the trash in your “Local Folders” and you will have to do that as another separate step.
I hope that helped/
Quote - Olivia Rust
Smart Folders right click Delete All Trash
“We do have this marked as a Feature request though and it will be implemented in future upgrades.”
Unquote - Olivia Rust
In Smart Folders as well as right click:
“Empty All Trash Folders”
I would like to see right click:
“Empty All Junk Folders”
Can this be added as a Feature Request?
yes thats work
but I hope to get one klick
