EMclient seems to hang on to attached images
I compose an email, attach an image from the PC, then send the email. All is good. A few mins later I go to delete the image from the PC, but Windows says it can’t because it’s in use by EMclient. FYI, I have EMclient set to minimize to systray, not close. If I do a full exit (via systray icon), the image deletes from the PC fine. Is this normal designed behavior?
There was an issue like this with one of the older 8.2 versions of eM Client, I think in early 2021.
It was fixed for version 9.
If you aren’t using the latest version of eM Client, which you can get in the Release History, what version of eM Client are you using? (Menu > Help > About)
Gary, I’m on 9.2.1735.
Well, it seems to be an occasional problem. I just tested it again with three emails with attachments and all three images subsequently deleted fine a minute later.
