eMclient not running smoothly
Having some problems today, eMclient not running as smoothly as a few days ago, sometimes ignores the mouse clicks. lost the desktop shortcut and does not allow me to replace it.
For the mouse issue, what happens if you restart Windows?
What happens if you replace the mouse?
To create a desktop shortcut, right-click on your desktop, and add a shortcut to the executable file. So “C:\Program Files (x86)\eM Client\MailClient.exe”
Gary, you are brilliant!
I changed the mouse and Yipee! problem solved.
Thank you.
