Not sure if this is a bug introduced in latest build 10.4.5642 (2a058e0) of emClient (Windows) but, in the messages list, I often use shift+arrow-down to select multiple mails to delete them.
It seems to me that on some occasion, when I do this, it now freezes emClient completly and I have to kill and restart it.
Anyone having emClient freezing indefinitely since latest update ?
Kind regards.
No i personally don’t get freezing when using shift+arrow-down to select multiple mails to delete with the latest V10.4.5647 & Win 11 (25H2). So try updating to the latest version via the release history page and see if that fixes it.
Before updating make a manual backup via “Menu / Backup” incase you need to restore for any reason. You can see when the backup is complete in Show Operations via the dropdown on the right of Refresh. Also close eM Client before updating,
Or failing that if still the same issue with the latest version, then try uninstalling eM Client and “don’t delete the database” when asked on the uninstall wizard. Then reinstall the latest version again. and see if a reinstall fixes it.
