I have an issue where emclient window keeps losing focus, in particular when creating a new message.
eg i’ll start a new message, start typing in the address and as i’m typing the message window will vanish, then I have to minimize emclient or tab between windows to find my new message.
Ive uninstalled, reinstalled emclient, updated video driver, checked all the settings, cant find what is causing the issue, any help would be appreciated.
Hi @Vivid,
sorry for reviving this old thread but I have the same issue and thought that it would have to be me, that I would inadvertently tap the trackpad or something but since you have the same issue, I might actually not go mad :D.
For me, it not only happens with a new message window but also with the main window. Mostly when my mouse pointer is above the message list (I think). It is really hard to pin down and I cant recreate it on purpose, it just happens randomly.
I am on macOS Ventura 13.0 with an M1 Pro. Are you also on a Mac or on a Windows machine?
Maybe, we can get someone from the emclient team take a look at it, I’d be willing to generate logs or whatever, if I knew how :).
Thanks and all the best
In that case I’d personally uninstall your existing -and possibly glitchy- Em Client, then restart your Mac and install the latest version of EMC >> Release History | eM Client
Back up your current EMC Data folder beforehand if need be.
(Menu > Settings > General > Storage*)
Hope this helps.
