Default mail app & rightclick send to windows 10
First enable .NET Framework 3.5, look at this link Installing the .NET Framework 3.5 on Windows 8, Windows 8.1 and Windows 10
https://msdn.microsoft.com/en-us/libr…
then enter settings -> default app and choose emclient as mail app.
will try that next tnx busy repair install on windows now, will reply with update
Windows 10 default setting requires going to SETTINGS SYSTEM DEFAULT APPS to set
Try that
It works tnx yishay
Dotnet 3.5 was the issue
Read my post.
I am having same problem, tried both suggestions above with no luck. Any ideas.
