Emclient do not open
My program has stopped opening on my PC since the last update, I’ve already repaired it but it doesn’t solve the problem, what’s the solution? Thanks.
Any errors displayed on screen or logged in MENU > OPERATIONS?
Please do the following:
  1. Close and uninstall eM Client, making sure NOT to delete the database folder when asked. That will ensure all your data and settings are there later.
  2. If it exists, delete the C:\Program Files (x86)\eM Client folder.
  3. Download and install the latest version from here: https://www.emclient.com/dist/latest/setup.msi
  4. Restart eM Client.
I have same issue. Latest version installed and now cant open the client
Did you reinstall following my instructions above?
I reinstalled the version and it now works.
